z1 - compression low after wiseco kit rebuild?
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: z1 - compression low after wiseco kit rebuild?
08 Oct 2013 09:16
#609233
15k miles on the cam chain are not an issue - but as the cam chain wears, your cam timing changes. For now I would just ride the bike. But as others mentioned, slotted can sprockets will get you better performance. So when you get a few weeks where you don't ride, replace or modify the cam sprockets and degree in the cams.
The shop manual tells you the wear limits on the cam chain - typically it takes 40,000+ miles to get close to this limit - although high lift cams and heavy duty valve springs will accelerate the wear. When you convert the wear limits to degrees, the change is massive - at least 3-4 degrees on the exhaust cam, and even more on the intake cam...
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • emy111
  • emy111's Avatar Topic Author
08 Oct 2013 09:52
#609235
@OMR
I plan to do the adjustable cam gears. But probably not until winter.
I did not have the head ported. I had it blasted clean, but no porting.
@Jeff
Good input. Next time I decide to pull this thing all apart, I'll do the cam chain.
Thanks for your input.
If you guys are interested in seeing my trip around the great lakes you can read about it here (my website):
www.chinonthetank.com/category/trips/great-lakes-tour/
And a couple photos below.
thanks again for all your input and recommendations.
Much appreciated!
-Ed
Image link:
Image link:
Image link:
Image link:
Image link:
Image link:
Image link:
Image link:
Image link:
Image link:
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
08 Oct 2013 10:21
#609239
you guys will remember that trip for the rest of your lives.
cool bike,glad you seem to have it closer to dialed in.
keep us posted,
