z1 - compression low after wiseco kit rebuild?
  • emy111
  • emy111's Avatar Topic Author
Re: z1 - compression low after wiseco kit rebuild?
07 Oct 2013 11:37
#609092
@Old Man Rock
thanks for your response.
I'm going to pick up a set of adjustable cam gears and try to set the lobe centers to 105.
Just out of curiosity...
Based on my photos, I don't have the cams off 1 tooth do I?
Also, I'll try your jetting recommendation and tweak from there.
thanks,
-Ed
  • Old Man Rock
  • Old Man Rock's Avatar
07 Oct 2013 11:49 - 07 Oct 2013 11:50
#609093
Hard to say in your images...
Maybe this will help... @ 1/4 TDC, lobe tips should aim as in right hand image to deck height...
Notice left image left intake cam off 1 tooth, slightly higher off decking...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 07 Oct 2013 11:50 by Old Man Rock.
  • emy111
07 Oct 2013 11:57
#609094
@Old Man Rock
Take a look at this image.
What do you think?
  • Old Man Rock
07 Oct 2013 13:53
#609115
Image is from a top view, get more down to the head decking height with your camera...
As far as I can in this image, left is high, right is lower than decking....
Rotate crank cw (forwad) 17mm crank nut under ignition plate.
Rotate where exhaust cam tip # 4 parallel to deck height.
You'll most likely find the 1/4TDC is not matched and intake came lobe is off as well...
Henceforth, not on the marks so to speak....
You can run @ 110 LC if you choose, just get them to align correctly at 1/4 TDC....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Dr. Gamma
  • Dr. Gamma's Avatar
07 Oct 2013 13:58 - 07 Oct 2013 14:00
#609118
I was reading what jetting Old Man Rock was running in his CR29's with air filters. There must be a big different in jetting when you run air filters over velocity stacks on CR's. I have always run CR33's on all my KZ motors with the long velocity stacks. My elevation was only 400 feet I think back in the Chicagoland area.
I ended up with a 62 slow jet, YY7 needle on 4th notch,120 or 122 main jet, but only a 180 or 190 air correction jet. If I ran a air correction jet of that size 230/250, it would never drop down to its idle speed. Plus if you backed off at high RPM's it would just coast, no real engine brake. With the 190 air correction jets when you revved the motor it would instantly drop back to its idle speed, and tons of engine brake when you backed off!! Could running air filters change the jetting that much.
I ran 1015 or 1105 motors with about 12 to 1 actual compression. Cams were either Yoshimura Super Bonnevilles(.400 lift 275 duration) or Norris 440sc's(.440 lift 282 duration) Yoshimura ported heads with 37.5 intakes.
I know out here in AZ I will have to run air filters because of all the dust. Its like living on the back straight at Eldora during a World Of Outlaw feature!!!
1986 RG500G 2 stroke terror.
Last edit: 07 Oct 2013 14:00 by Dr. Gamma.
  • emy111
07 Oct 2013 14:20
#609127
Okay.
I'm thinking my cam timing is off.
I'll verify when I get home.
Like I said earlier... the bike seems to run pretty damn good.
And it's pretty darn fast.
Lets say my intake cam is retarded 1 tooth.
Would there be any potential engine damage from this?
Keep in mind I just did a 3000 mile trip.
I took photos of where the cams were situated when I initially disassembled the engine.
And I just put the new cams in as the old cams were.
I wonder if the cams were off when I got the bike.
Like I said... it was a junker.
Thank you again for all your responses.
-Ed
  • emy111
07 Oct 2013 14:23
#609129
@Dr. Gamma
Thanks for your input about your jetting specs.
Aside from cam timing... I'm going to try and make some needle / jet adjustments based on your feedback and OMR feedback.
-Ed
  • sbc1320
  • sbc1320's Avatar
07 Oct 2013 17:22
#609151
emy111 wrote: Lets say my intake cam is retarded 1 tooth.
-Ed
Nope not if it is running good like you say. If you had bent a valve you would notice it. Recheck your timing marks again. Good luck and you have one good looking KZ there to be proud of.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • emy111
07 Oct 2013 22:14 - 07 Oct 2013 22:16
#609184
Hey guys,
I got home from work and pulled the valve cover off.
First image is where the lobes fell since my rebuild and during my long trip.
I rotated both the intake and exhaust cam 1 tooth advanced as seen in the second pic.
They look like they line up better now. Lining up directly at the T mark.
What do you guys think?
I went for a ride and the bike seems a bit faster now.
Seems to idle better too.
Compression also jumped from 125 to 175ish.
I increased my main jet from 110 to 115. It feels good.
I still plan to do adjustable cam gears and actually set lobe centers to 105, but until I do that... do the cams look like they're lining up more closely to how they should be?
Let me know what you guys think.
Thanks.
-Ed
Before
After
Last edit: 07 Oct 2013 22:16 by emy111. Reason: text edit
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
07 Oct 2013 23:12 - 07 Oct 2013 23:25
#609190
Did you replace the cam chain - it looks like a stock cam chain in the picture? If not, how many miles were on it?
The stretch (wear) can confuse as you'll end up with the cams mildly retarded or off a tooth if you are not careful.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Last edit: 07 Oct 2013 23:25 by Jeff.Saunders.
  • emy111
08 Oct 2013 00:11
#609202
@jeff
I did not replace the cam chain. I would guess there are 15k miles on it.
-Ed
  • Old Man Rock
08 Oct 2013 07:26
#609228
If second image at 1/4 TDC mark and @ 28 tooth count then spot on in the alignment! ;)
Damn, looks 100% exactly like my first OFF Lobe center image with that build.... :laugh: :laugh: :laugh:
Now, you can leave it @ 110 lobe centers if you choose, probably save you some $$$ and a whole lot of headache not having to deal with CAM Degreeing... Pending your riding style, desired power band range (low, mid or WOT throttle), idle conditions or desire just to learn.
Also, possibly I missed it but was the head ported as well... If the old girl hauls ass as is after this timing adjustment, get your carb jetting correct and go for a ride.... If she purrs like a kitten at idle, pulls like a rape ape for ya, then shit leave it for now and enjoy your ride. You can always go the adjustable cams later on if you choose... ;)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
