Chain Maintenance
  • TheDude
  • TheDude's Avatar
Re: Chain Maintenance
22 Dec 2013 11:45 - 22 Dec 2013 11:45
#616136
Does warm water and a tooth brush work to clean the chain?
Here's a picture of a bike that I just bought...needs some work.
Can I clean the sprocket and it's surroundings w/ warm water? Will I have to lube the sprocket after cleaning it?
[IMG
1982 Kawasaki KZ550 A3
Last edit: 22 Dec 2013 11:45 by TheDude.
22 Dec 2013 13:29
#616145
That sprocket looks shot to me. I would replace both sprockets and the chain. While you have them off you can clean the surrounding areas. Ed
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
22 Dec 2013 14:18
#616147
I use kerosene in a spray bottle to wash the grit from the chain.
Follow by "Motorex synthetic off road chain lube".
It doesn't have the fling factor. ;)
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
  • TheDude
  • TheDude's Avatar
22 Dec 2013 14:23
#616148
650ed wrote: That sprocket looks shot to me. I would replace both sprockets and the chain. While you have them off you can clean the surrounding areas. Ed
that sounds like a good idea. I'll do that. Is there a chain you recommend?
I remember reading somewhere that some belts have o-rings and kerosene can eat away at the ring. That's why I was thinking water a brush and some elbow grease would do the job.
  • JR
  • JR's Avatar
22 Dec 2013 15:09
#616154
Water won't do any good. It will just cause rust.
Lots of good suggestions above above for cleaning. I use a rag with chain lube to clean the chain. Never had a problem with kerosene on a rag it evaporates quickly. On some chains you may find the links will say what type . I can't make out what it says on your chain. Mine says DID 630 O ring. DID is the manufacturer and 630 is size.
  • koolaid_kid
  • koolaid_kid's Avatar
22 Dec 2013 15:24
#616155
Kerosene will not harm the o-ring, it is a distillation of petroleum.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • koolaid_kid
22 Dec 2013 15:26
#616156
BTW, DuPont now makes a dedicated Chain Lube as well as a chain cleaner.
1983 GPz 750
22 Dec 2013 15:27
#616157
According to Kawasaki.com your KZ550-A3 chain is a 530 x 100. I have had excellent service from my D.I.D. O-ring chain. Their X-ring chain is also supposed to be excellent. Be sure to replace both sprockets and the chain as a set. A worn sprocket will prematurely kill a chain, and a worn chain will prematurely kill a sprocket. Just use chain lube to maintain and clean the chain. You do not need to use anything else. See link below. Ed
www.kzrider.com/forum/2-engine/591153-chain-maintenance#606569
Attachment 00004_2013-12-22.jpg not found
  • sbc1320
  • sbc1320's Avatar
22 Dec 2013 15:28
#616158
I second WD40 sprayed on a rag an d wiped down. WD40 is also excellent for removing road tar on your paint jobs.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • koolaid_kid
22 Dec 2013 15:31
#616160
The problem with WD40 is that it is also a penetrant,and can get past the orings and wash out the inner lubricant.
1983 GPz 750
  • bountyhunter
  • bountyhunter's Avatar
22 Dec 2013 15:54 - 22 Dec 2013 15:54
#616166
that sounds like a good idea. I'll do that. Is there a chain you recommend? .
Z1 had the best buy on a good X-ring chain when I needed one.
Last edit: 22 Dec 2013 15:54 by bountyhunter.
  • TheDude
  • TheDude's Avatar
22 Dec 2013 16:39
#616174
650ed wrote: According to Kawasaki.com your KZ550-A3 chain is a 530 x 100. I have had excellent service from my D.I.D. O-ring chain. Their X-ring chain is also supposed to be excellent. Be sure to replace both sprockets and the chain as a set. A worn sprocket will prematurely kill a chain, and a worn chain will prematurely kill a sprocket. Just use chain lube to maintain and clean the chain. You do not need to use anything else. See link below. Ed
Appreciate that ed. I'm replacing a clutch cable, but after that I'll move to the chain.
Would you recommend a shop replace and tighten the chain?
I'd like to do it myself for the experience and to save $$$. I've worked on my cars in the past and think of myself as a novice mechanic.
