Clacking noise from left side of motor
- Beaner242
21 Jul 2013 23:54
1982 KZ1000K LTD Chopper
- Motor Head
Re: Clacking noise from left side of motor
22 Jul 2013 00:04 - 22 Jul 2013 00:10
Whats the teeth on the sprockets look like? Are they worn? Could be worn sprockets. Chain and sprockets would need replacing as a set. Yours is a 630, z1enterprises has them as well as sprockets and chain for a 530 conversion if desired. Worn chain and sprockets on a motorcycle can be Very dangerous.
I've got the same bike, and run the 630 in a o-ring chain. 20K miles and looks brand new.
Last edit: 22 Jul 2013 00:10 by Motor Head.
- Beaner242
22 Jul 2013 00:45
It's not the chain or sprockets. They are barely worn. It's coming from inside the case. It sounds like something slapping the inside of the case on the lower left side. Like metal on metal. I guess I'll pull the clutch basket next
- Motor Head
22 Jul 2013 10:41
Lower left side, clutch basket is on the right. Not the chain/ sprockets. Maybe either the Stator/ rotor, starter clutch. Or possible transmission out put bearing. If you pull the covers off of the left side looking for loose parts, if you don't see anything. Back off your chain tension and see if your Sprocket shaft is loose. The transmission cover comes off easily and you can look at the bearing. Or you can pull the oil pan pretty easy for inspection, probably needs cleaning from years of clutch gunk anyway.
- gpz1170
22 Jul 2013 14:05
Beaner242
I know you said noise on the left side, but noises in a motor can be deceiving. The first thing I would do is adjust the cam chain tensioner and see if it still does it. A loose cam chain usually makes the most noise on deceleration. If not that then I agree, check the clutch basket ( the weak link in a J motor ). While decelerating and hearing the noise, pull the clutch lever in and see if it stops or lessens.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- Beaner242
22 Jul 2013 14:55
sorry, i thought the clutch was on the left side but its not is it. LOL I pulled the case off and there is nothing loose that i can see or feel. ill try loosening the chain and check the sprocket shaft. and yes gpz1170 it does almost quit when pulling the clutch in.
- slayer61
- KZR FLAG RELAY CARRIER #62
22 Jul 2013 15:47 - 22 Jul 2013 15:47Only the lever!Beaner242 wrote: i thought the clutch was on the left side but its not is it.
Last edit: 22 Jul 2013 15:47 by slayer61.
- Beaner242
22 Jul 2013 16:44
Touche!
- gpz1170
22 Jul 2013 22:15
Beaner242
If that's the case, pull the clutch basket, no splitting the cases on a J motor, and inspect the spring on the rear of the basket. If they are loose, that's probably the noise.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
The following user(s) said Thank You: Beaner242
- Beaner242
22 Jul 2013 23:31
Ok thanks don. That will be the next step
- Beaner242
24 Jul 2013 22:55
Well finally got to work on it some more. I took the big nut off the clutch basket trying to get it out. All that did was let me pull all the plates and steels out. The basket hits the case on the right side so there is no way to get it out. Scratched my head and put it back together. Moved around to the other side. Pulled the bolt out that hold the basket with the magnets in it. That won't come off either. Pressed on shaft? Back to square one. I guess my next step is checking the cam chain? I tried reading how to do it in the Manual but got a little confused. Guess ill reread it again.
- Cuff
25 Jul 2013 01:57
I have the very same sound you do. It almost sounds like a fluid click. Mine happens in neutral when chopping the throttle however and I've narrowed it down to (in my head at least
a sprag starter clutch issue.
