Clacking noise from left side of motor
21 Jul 2013 23:54 #597640 by Beaner242
Clacking noise from left side of motor was created by Beaner242
:angry: this is hard to explain so bear with me. I've had this bike for about a month now and it's getting worse. When I test drove the bike I noticed a noise when I let off the throttle. It sounded like the chain slapping from being loose. After my sprocket incident I tightened the chain up but the noise is now getting worse and after paying more attention its coming from the lower case not the chain area? It only does it above 30 mph and only when I let off the throttle. The faster I'm going it seems worse when I let off. I pulled the side case off this eve and see nothing loose or anything that it could be just from looking. Any ideas before I tear deeper into the charging and clutch?
1982 KZ1000K LTD Chopper
  • Motor Head
22 Jul 2013 00:04 - 22 Jul 2013 00:10 #597642 by Motor Head
Replied by Motor Head on topic Clacking noise from left side of motor
Whats the teeth on the sprockets look like? Are they worn? Could be worn sprockets. Chain and sprockets would need replacing as a set. Yours is a 630, z1enterprises has them as well as sprockets and chain for a 530 conversion if desired. Worn chain and sprockets on a motorcycle can be Very dangerous.
I've got the same bike, and run the 630 in a o-ring chain. 20K miles and looks brand new.
Last edit: 22 Jul 2013 00:10 by Motor Head.
22 Jul 2013 00:45 #597652 by Beaner242
Replied by Beaner242 on topic Clacking noise from left side of motor
It's not the chain or sprockets. They are barely worn. It's coming from inside the case. It sounds like something slapping the inside of the case on the lower left side. Like metal on metal. I guess I'll pull the clutch basket next
  • Motor Head
22 Jul 2013 10:41 #597684 by Motor Head
Lower left side, clutch basket is on the right. Not the chain/ sprockets. Maybe either the Stator/ rotor, starter clutch. Or possible transmission out put bearing. If you pull the covers off of the left side looking for loose parts, if you don't see anything. Back off your chain tension and see if your Sprocket shaft is loose. The transmission cover comes off easily and you can look at the bearing. Or you can pull the oil pan pretty easy for inspection, probably needs cleaning from years of clutch gunk anyway.
22 Jul 2013 14:05 #597714 by gpz1170
Replied by gpz1170 on topic Clacking noise from left side of motor
Beaner242
I know you said noise on the left side, but noises in a motor can be deceiving. The first thing I would do is adjust the cam chain tensioner and see if it still does it. A loose cam chain usually makes the most noise on deceleration. If not that then I agree, check the clutch basket ( the weak link in a J motor ). While decelerating and hearing the noise, pull the clutch lever in and see if it stops or lessens.
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
22 Jul 2013 14:55 #597720 by Beaner242
sorry, i thought the clutch was on the left side but its not is it. LOL I pulled the case off and there is nothing loose that i can see or feel. ill try loosening the chain and check the sprocket shaft. and yes gpz1170 it does almost quit when pulling the clutch in.
  • slayer61
  • KZR FLAG RELAY CARRIER #62
22 Jul 2013 15:47 - 22 Jul 2013 15:47 #597730 by slayer61
Replied by slayer61 on topic Clacking noise from left side of motor
Beaner242 wrote: i thought the clutch was on the left side but its not is it.
Only the lever!
:unsure:
Last edit: 22 Jul 2013 15:47 by slayer61.
22 Jul 2013 16:44 #597741 by Beaner242
Touche!
22 Jul 2013 22:15 #597800 by gpz1170
Beaner242
If that's the case, pull the clutch basket, no splitting the cases on a J motor, and inspect the spring on the rear of the basket. If they are loose, that's probably the noise.
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
The following user(s) said Thank You: Beaner242
22 Jul 2013 23:31 #597807 by Beaner242
Ok thanks don. That will be the next step
24 Jul 2013 22:55 #598152 by Beaner242
Well finally got to work on it some more. I took the big nut off the clutch basket trying to get it out. All that did was let me pull all the plates and steels out. The basket hits the case on the right side so there is no way to get it out. Scratched my head and put it back together. Moved around to the other side. Pulled the bolt out that hold the basket with the magnets in it. That won't come off either. Pressed on shaft? Back to square one. I guess my next step is checking the cam chain? I tried reading how to do it in the Manual but got a little confused. Guess ill reread it again.
25 Jul 2013 01:57 #598167 by Cuff
Replied by Cuff on topic Clacking noise from left side of motor
I have the very same sound you do. It almost sounds like a fluid click. Mine happens in neutral when chopping the throttle however and I've narrowed it down to (in my head at least ;-) a sprag starter clutch issue.
