Kz750 twin backfiring
- Schmeck
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
- bountyhunter
- Thank you received: 337
- bountyhunter
- Thank you received: 2829
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ750-G1 (LTD II) (1980)
Here are some on eBay:
- Schmeck
- Schmeck
- Cynjut
- Thank you received: 26
It's not the drop that feeds the fuel; it's pressure above the drop that feeds the fuel. The petcock is an inch tall and the gas is anywhere from zero to six inches taller.
In other words, my advice is to save your money and put it to something that will help you more later.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
Schmeck wrote: I do have one last question ( please excuse me I do not know enough) . How would I go about the fuel lines from the petcock to the carburetors . It only drops about an inch and its hard for the fuel to flow down since there isnt much drop. I have a single outlet petcock going to a 3 way connector. Im really considering buying a dual outlet petcock but 100$ is alot for the ones I have found .
It doesn't matter if the fuel drops 1 inch or 10 - fuel flows downhill and it will flow fast enough to fill the carb bowls regardless of the amount of drop. The fuel flows through the petcock down the fuel line into the carb bowls and fills them to a specific level at which the float valves stop the flow. As fuel is drawn through the carbs it is pulled from the bowls, not the fuel lines (remember, these are carbs, not fuel injection). As the fuel is drawn from the carb bowls and the fuel level in the bowls drops the float valves open and allow more fuel to flow from the petcock into the bowls - this keeps the fuel in the bowls at the proper level as you ride.
What makes you believe you need a petcock with 2 outlets? The number of outlets on the petcock is not determined by the number of carbs. The petcock for a 4 carb KZ750 4 cylinder bike only has 1 outlet. A 2 outlet petcock is only needed if the carbs have 2 separate inlets and are not fed through a common "T." I'm not familiar enough with KZ750 Twin carbs to know how they are normally set up, but if the stock petcock had 1 outlet that's all you need. If it had 2 outlets you should have one with 2 outlets. Ed
- Schmeck
- car5car
- Banned
- Thank you received: 20
You can feel that popping, if you hold your hand behind muffler.
You can find out which cylinder is popping.
96 Yamaha Royal Star
82 Yamaha Virago 920
- Schmeck
