Kz750 twin backfiring
- Schmeck
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
- bountyhunter
- Thank you received: 337
You should also check for vacuum leaks.
- bountyhunter
That sounds like a lean pilot system, either vacuum leak and/or the mixture screws are set too lean.Schmeck wrote: When you crack the throttle the bike sounds great until u let off the throttle and it will do a single backfire every so often .
Another thing: the 750 twins with BS-38 come with either 40 or 45 pilot jets which are too lean. They run much better with 50 pilots. The 50s stopped the "pop pop" when I let off the gas.
- Schmeck
- Thank you received: 2829
- Schmeck
- bountyhunter
Do the weights move freely and smoothly?
Do the springs keep them in or do they wobble and flop around loose?
- bountyhunter
- Schmeck
- Schmeck
