Loctite on exhaust nuts????
- ramtough_63
27 May 2013 15:39
I have had my exhaust off a few times and have had to tighten it a few time through general going over
is loctite a good idea I use it in several other places
have always heard to use antiseize on stainless bolts to aluminum
locktite on nut bolt combinations was curious about if its a good idea on exhaust nuts
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Re: Loctite on exhaust nuts????
27 May 2013 16:09
No Loctite on exhaust nuts. To Much heat
OH and Happy Memorial Day Ram !!!
- MFolks
27 May 2013 16:16
Some grades of red loctite are good up to 450 F, but just how hot does your exhaust system studs get? Usually, torquing them will be good enough.
- ramtough_63
27 May 2013 17:08
thanks guys happy memorial day to everyone
couldnt remember seems like I was told no locktite on exhaust years ago but
my memory isnt that good
getting closer every day to getting this heap on the road be glad when I have the funds
to do a complete rebuild
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- bountyhunter
27 May 2013 17:47
I use lock washers on mine, no Loctite. It will just burn off.
- trianglelaguna
27 May 2013 21:41
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- slayer61
- KZR FLAG RELAY CARRIER #62
27 May 2013 22:48
I have a vintage flattrack race bike and everything that has ever vibrated off of that bike has been drilled, torqued to factory specs, and safety wired. Including exhaust nuts. Done right, they never rattle loose again and can be removed by simply snipping the wire and removing the nut. Paul.
- Dr. Gamma
27 May 2013 23:55slayer61 wrote: I have a vintage flattrack race bike and everything that has ever vibrated off of that bike has been drilled, torqued to factory specs, and safety wired. Including exhaust nuts. Done right, they never rattle loose again and can be removed by simply snipping the wire and removing the nut. Paul.
Thats the best way to do it.
It least you know nothing of importance will fall off your bike at the worst possible time!!
Just hate drilling all those little holes in all those nuts and bolts!!!!!
Used to buy 1/16th drill bits by the gross!!!!
1986 RG500G 2 stroke terror.
- bountyhunter
28 May 2013 01:28
You can also use the technique Harley owners use. Always ride in pairs. The trailing rider has the responsibility of picking up the parts that fall off the leading bike. After ten minutes, reverse positions.
- zed1015
28 May 2013 06:08
Never use Thread lock on the exhaust nuts.
It's ok for installing the actual studs in the head but not on the nuts.
Always fit the nuts with copper grease to prevent seizure and use spring washers to secure them.
I use a plain washer against the flange first if it's alloy to stop the spring washer chewing the soft alloy.
I've never had them come loose after the initial first ride and following re-torque.
- Powerstroke_fan
28 May 2013 07:54
I am not sure about on the exhaust studs.Ive never tried this either, but. I saw on power block tv on spike tv. They showed that you can make your own lock nuts by using the regular nut and running fishing string thru the nut then starting the nut on the stud or bolt. I guess they say it really works. like stated, i dunno if it would work on the exhuast. It probably would get to hot and melt.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
28 May 2013 10:09 - 28 May 2013 10:09
One suggested method to do the exhaust nuts is to snug them up by feel without over tightening, ride the bike, then re-snug them. The torque value may be INCH-pounds, so you don't want to crank them down too tight. I use a small wrench & apply finger pressure (instead of grabbing a bigger wrench & using a death grip)... an unnecessarily broken exhaust stud would be a real drag. The 650's are 6mm, so they'd be easier to snap off than your bike's 8mm.
Last edit: 28 May 2013 10:09 by martin_csr.
