Low Compression
  • Motor Head
  • Motor Head's Avatar
Re: Low Compression
05 Jun 2013 21:01
#590984
Z1 does indeed sell the correct shims for your bike. They will also have gaskets for you, along with other stuff. Good Idea to save a bit on freight and get a couple of oil filters or something to fill an order. ;)
  • BIGKEVIN
  • BIGKEVIN's Avatar Topic Author
Re: Low Compression
05 Jun 2013 22:11
#590995
Are the 29 mm shims the correct ones for the 1976 KZ 900 ?
1976 KZ900
2006 ZX6R
  • moneypit
  • moneypit's Avatar
Re: Low Compression
05 Jun 2013 23:11
#591006
BIGKEVIN wrote: Are the 29 mm shims the correct ones for the 1976 KZ 900 ?
You are correct. 29mm
2-76 kz900
St Paul MN
Re: Low Compression
05 Jun 2013 23:13 - 05 Jun 2013 23:13
#591008
Yes, 29 mm valve shims are correct for 1976 KZ900.
Click here > 29 mm valve shims at Z1E
Good Fortune! :)
Last edit: 05 Jun 2013 23:13 by Patton.
  • BIGKEVIN
Re: Low Compression
06 Jun 2013 06:33
#591030
OK, thanks. What is the correct part number for the valve cover gasket ? I am going to replace that also, but I dont see one for a 1976 KZ900.
1976 KZ900
2006 ZX6R
Re: Low Compression
06 Jun 2013 07:08
#591032
BIGKEVIN wrote: OK, thanks. What is the correct part number for the valve cover gasket ? I am going to replace that also, but I dont see one for a 1976 KZ900.
Click here > Z1E's KZ900 valve cover gasket
Good Fortune! :)
  • BIGKEVIN
Re: Low Compression
06 Jun 2013 08:56
#591051
Thanks for the info Patton. I will be ordering my shims and valve cover gasket later today.
1976 KZ900
2006 ZX6R
Re: Low Compression
06 Jun 2013 12:20
#591077
Before installing the new gasket, hopefully the mating surfaces (head and cover) may be restored to an as-new clean condition.
When doing so, the new gasket may be installed "dry" without any resulting leakage past the gasket.
But do use a light application of sealer on the curved and flat edges of the cam end plugs, to prevent oil seepage past the plugs.
Be sure to thoroughly clean the cam plugs before applying sealer to them.
And also clean the recess where they fit into the head.
Any oil residue on the metal parts will prevent the sealer from properly adhering.
Good Fortune! :)
  • BIGKEVIN
Re: Low Compression
06 Jun 2013 18:58
#591132
Thanks for all of the information Patton. I should be getting the parts Saturday or Monday.
1976 KZ900
2006 ZX6R
  • BIGKEVIN
Re: Low Compression
10 Jun 2013 18:16
#591645
I got the shims the other day and got them all installed. I checked the valve clearances and they all seem to be loose. Is the clearacne supposed to be taking when the cam lobe is pointing straight up or pointing directly away from the valve ?
1976 KZ900
2006 ZX6R
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Low Compression
10 Jun 2013 18:43
#591648
You want the cam lobe should be pointing away from the bucket.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • BIGKEVIN
Re: Low Compression
10 Jun 2013 18:53
#591649
OK, I measure all of mine with the highest point of the lobe pointing straight up, which is not pointing directly away from the bucket. Anyone know what the valve difference is between straight up and pointing directly away from the bucket ? I guess I need to take all of the measurements again ?
1976 KZ900
2006 ZX6R
