Low Compression
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Low Compression
03 Jun 2013 21:30
#590726
You wont i am sure others have used them. Have you tried searching for instructions on line?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • BIGKEVIN
  • BIGKEVIN's Avatar Topic Author
Re: Low Compression
03 Jun 2013 21:41
#590728
I am doing that now also.
1976 KZ900
2006 ZX6R
Re: Low Compression
04 Jun 2013 18:31
#590850
BIGKEVIN wrote: I got my ZSM001-113 shim tool today and tried to get the shims out to measure them. I turned the highest point of the cam down to depress the valve, but I couldn't figure out where to put the tool to keep the valve depressed so I could get the shims out. The tool didn't come with directions and probably isn't hard to use, but as usual, I probably made it harder than it is. Does anyone have a video or good directions on how to use to the tool so I dont mess up the cams or the valves ?
Under FILEBASE (in the ribbon toward top of the computer monitor screen), there's a complete KZ900 Factory Service Manual that may be downloaded for free.
Here's a direct link to the download.
Click here > www.kzrider.com/filebase/doc_download/43...asaki-service-manual
After downloading, on page 16, there are instructions and a picture of the special tool positioned to remove/replace the shim.
Good Fortune! :)
  • BIGKEVIN
Re: Low Compression
04 Jun 2013 20:51
#590870
I go took all of the shims out one at a time and measured all 8 of them.
#1 exhaust measured 2.70
#1 intake measured 2.55
#2 exhaust measued 2.67
#2 intake measured 2.50
#3 exhaust measured 2.60
#3 intake measured 2.70
#4 exhaust measured 2.70
#4 exhaust measured 2.70.
All of the shims can be moved when the cam lobe is pointed away from the spring.
I plan on ordering all new shims. Can someone tell me what shims I should order for each intake and exhaust ? Thanks
1976 KZ900
2006 ZX6R
Re: Low Compression
04 Jun 2013 21:57 - 04 Jun 2013 22:00
#590877
BIGKEVIN wrote: I go took all of the shims out one at a time and measured all 8 of them.
What was each valve's clearance before removing its shim?
For the valves with incorrect clearance, some swapping of the shims may be possible in order to minimize the number of new shims needed.
Where clearance is insufficient -- but shim can be moved -- usually the next size smaller shim will regain necessary clearance.
Good Fortune! :)
Last edit: 04 Jun 2013 22:00 by Patton.
  • BIGKEVIN
Re: Low Compression
04 Jun 2013 22:00
#590878
The valve clearance on all of the valves were tight. I could not get a .002 inch feeler gauage in any of them
1976 KZ900
2006 ZX6R
  • Powerstroke_fan
Re: Low Compression
04 Jun 2013 22:08
#590879
Its really hard to say exactly. Did you verify you could not get your thinist feeler gauge in between the cam and bucket? But you could rotate the shim in the bucket with the lobe pointing away? If thats true for the buckets, then you would want to drop probably one size on each. Two sizes would defitenly do it, if the one size drop dosent. But two sizes might be to much. So i would just start with one.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
  • Motor Head
  • Motor Head's Avatar
Re: Low Compression
04 Jun 2013 22:10
#590880
Good you measured all of the shims.
Use the thinner shims you have now to check the clearances on the others. So use a 260 where there was a 270 and so forth checking to see if the clearance is correct.
If you couldn't fit a feeler gauge of .002" in, but they would spin. i would suggest Two shim sizes less. So that is where you had a 270 a 260, where you have a 255 a 245. You shouldn't need to buy all new shims, just the ones you can't move to adjust to the correct clearance.
  • BIGKEVIN
Re: Low Compression
04 Jun 2013 22:15
#590881
OK, that makes sense. I'll put a 2.60 where a 2.70 currently is and then measure to see if the clearnace is good or not. Thanks for the help.
1976 KZ900
2006 ZX6R
  • geobass
  • geobass's Avatar
  • 75 Z1-B
Re: Low Compression
04 Jun 2013 22:28
#590883
Take the smallest shim...2.50 and use it to measure the clearances on the other valves. Switch the ones you can to get you in range. On my 900 if the shims were tight I had to go down 2 sizes to get me in range. .5 mm = 2 thousands of an inch.
Re: Low Compression
04 Jun 2013 22:30 - 04 Jun 2013 22:31
#590884
Factory specified clearance is 0.05~0.10 millimeters.
Where the intake measures 0.05 mm, many owners prefer 0.10 mm on the intakes.
Some owners also prefer up to 0.15 mm on the exhaust valves.
Good Fortune! :)
Last edit: 04 Jun 2013 22:31 by Patton.
  • BIGKEVIN
Re: Low Compression
05 Jun 2013 19:31
#590975
I moved the 2.5 mm shim to the valves that had the 2.7 mm shims and I was able to get the feeler gauage between the shim and cam. Looks like I need to move down .2 mm on all the shims. Are the 29 mm shims that Z1 sells the correct shims for a 1976 KZ 900 ? Thanks for all replies and help.
1976 KZ900
2006 ZX6R
