- Thank you received: 52
KZ400 oil/gas coming from breather!! HELP
- kzz1king
23 May 2013 19:26 #588931
by kzz1king
Home built KZ1000 turbo setup
Replied by kzz1king on topic KZ400 oil/gas coming from breather!! HELP
I cannot think of any good reason for a whole in the overflow tube. Did gas run out that hose before? It would not cause your crankcase to fill though.
Wayne
Wayne
- Juicyk
- Who needs guages?
23 May 2013 21:40 #588947
by Juicyk
Graphic Designer that likes to get out from behind the computer to get greasy!
Replied by Juicyk on topic KZ400 oil/gas coming from breather!! HELP
Fuel an oil only ever came out the overflow. But I've got a new peacock and tomorrow ongoing to do an oil change. Tomorrows ride should tell us if it's been fixed.
- Juicyk
- Who needs guages?
28 May 2013 12:54 #589584
by Juicyk
So the petcock that I bought, will not work due to the opening in the tank and the location of the hardware holes. I can have photos tomorrow when my phone gets fixed.
I'm beginning to think my bike might not be a '76 or that whom ever owned it prior to myself, messed more than originally thought.
- Thank you received: 1656
28 May 2013 13:55 - 28 May 2013 14:01 #589590
by martin_csr
Replied by martin_csr on topic KZ400 oil/gas coming from breather!! HELP
Have you compared your tank & fuel valve to the diagrams? Kawasaki.com or Partzilla.
The bolt-hole spacing on some bikes is 44mm - usually 70s models.
The spacing is 34mm on others - typically 80s models I'd guess (81 650-CSR = 34mm).
Some fuel valves thread onto the tank.
The hole in the tank varies as well.
Last edit: 28 May 2013 14:01 by martin_csr.
The following user(s) said Thank You: Juicyk
- Juicyk
- Who needs guages?
28 May 2013 14:22 #589595
by Juicyk
After seeing the diagram my petcock is stock, just installed in a very questionable way :side:. Must just be a stocking error with the supplier I purchased from because it specifically said it was for a 76. Looks like ill just rebuild the stock one and slap it back on
martin_csr wrote: Have you compared your tank & fuel valve to the diagrams? Kawasaki.com or Partzilla.
