- Thank you received: 1616
KZ400 oil/gas coming from breather!! HELP
- loudhvx
Here's a video. At first, no flow. Then when i pressurize the tank, it flows.
You will want a metal screen filter or scintered brass/bronze, made for bikes.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Juicyk
- Who needs guages?
loudhvx wrote: That filter will be problematic. They need more than gravity to work. They eventually seal up and stop flowing. With a fuel pump they work fine.
Thanks, I have since the video mounted the filter sideways and it flows just fine now.
Graphic Designer that likes to get out from behind the computer to get greasy!
- Juicyk
- Who needs guages?
- KZipper
- Thank you received: 3
I highly recommend a filter like this one:
It can be taken apart and cleaned as necessary.
Attachment seethrufilter.jpg not found
'81 KZ650H1 CSR
- loudhvx
I use both of these types.
This first one is nice, but make sure to get it from Z1 Enterprises. I've seen cheap knockoffs that turned yellow and soft over time. I've had one of these for a few years and it appears to be holding up.
www.z1enterprises.com/ItemDetails.aspx?i...2f4%22&item=MA2345-1
This second one comes apart with a cleanable scintered bronze element inside.
Just make sure to screw it back together tightly. I left one loose once and it started dripping a few days later.
www.denniskirk.com/emgo/metal-fuel-filte...80612.prd/180612.sku
1981 KZ550 D1 gpz.
Other links.
- gengomerpyle
- Thank you received: 17
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- Juicyk
- Who needs guages?
gengomerpyle wrote: is that a vacuum fed petcock?
I'm assuming it was. But it has a hose that has been blocked off. Either way it doesn't turn off the fuel flow. I ordered a replacement non vacuum.
- gengomerpyle
1982 GPZ750R1 ELR
1971 Honda CB750K
- Juicyk
- Who needs guages?
- Juicyk
- Who needs guages?
While pulling the bowls I did another inspection just in case I missed something. I noticed what looked like a small circular hole at the base of one of the brass overflow tubes. To me it looked as if it was supposed to be there but like I said earlier I'm not expert. Any thoughts?
- jvevea
1975 KZ400D morphing into a cafe' dual sport
2012 Ducati 848 Corse
life is hard so remember who your friends really are and the things that made you smile.
- Juicyk
- Who needs guages?
www.amazon.com/gp/product/B00B4XDO8M/ref...00_i00?ie=UTF8&psc=1
