shims
  • vondikka
  • vondikka's Avatar Topic Author
shims
02 May 2013 02:32
#585236
how do i remove the valve shims in my 78 kz650? I have no clearance on number 4 and want to install a smaller shim, but don't know how to remove the original. Does it require a special tool?
78 KZ650 C2
76 kz400 D3
  • bluezbike
  • bluezbike's Avatar
Re: shims
02 May 2013 02:44
#585240
The 650's need the cams removed as the shims are under the buckets...make sure you do all your measurements accurately for all the valves before you take out the cams so it only has to happen once. Also make sure of the cam cap bolt torque settings...get that # from the FSM not Clymer manual as it is sometimes wrong.
79 KZ 1000 LTD
  • wireman
  • wireman's Avatar
Re: shims
02 May 2013 02:44
#585241
You need to remove the camshaft on that side of motor on the 650 :)
Re: shims
02 May 2013 03:17
#585247
RonKZ650 wrote: Yes, you need to lock the tensioner as you already know. This is the 6mm bolt on the side of the tensioner body. To lock the tensioner, simply remove that short bolt and thread in a longer bolt that will tighten against the tensioner to hold it in place. After this is done remove your valve cover. If you're careful and no moron has used gasket sealer you can remove the cover without ruining the gasket and it can be reused indefinately. Now to be safe turn the motor over clockwise with a 17mm socket on the right end of the crank until your timing marks for 1-4 indicate TDC. Now look at the cams and see the arrow on the exhaust sprocket pointing straight forward aligned with the top surface of the head and your intake facing straight back lining up with the top of the head. If the arrows are not this way, turn the motor over 1 complete revolution until 1-4 are again at TDC. Now you have cams in correct position should an accident happen during disassembly. Now the way to remove the cams as to not disturb the timing. Of course first remove the center idler sprocket from between the cams and now work on one cam at a time. Remove all 4 cam caps from one cam, push down on the chain where your center idler was and at the same time lift the cam towards the center of the engine. Be sure and keep the chain tight going down in the engine and keep all slack between the cams. Once the cam is in the center of the engine you can do your shim swaps, then carefully reposition the cam in place. The important part is keep all slack between the cams and the chain always tight going down into the engine. Bolt up the caps and you're done with that cam. Repeat for the other cam. Do it right and timing has not been goofed up. This is direct from Kawasaki 4/77 service bulletin. Get it all bolted up, reinstall your short bolt in the tensioner and you're done. Tighten cam caps to 8ft/lb or less.
Good Fortune! :)
The following user(s) said Thank You: wireman, bluezbike
  • Old Man Rock
  • Old Man Rock's Avatar
Re: shims
02 May 2013 08:48
#585260
You need to get the service manual is what you truly need... ;)
Here's a link to later year model but pretty much the same.
Free KZ650 service manual
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
The following user(s) said Thank You: bluezbike
Re: shims
02 May 2013 09:36
#585265
Old Man Rock wrote: You need to get the service manual is what you truly need... ;)
+1
Trying to replace shims without using the Kawasaki Service Manual will be the kiss of death to your engine. Ed
  • Matteson
  • Matteson's Avatar
Re: shims
02 May 2013 10:48
#585273
vondikka wrote: how do i remove the valve shims in my 78 kz650? I have no clearance on number 4 and want to install a smaller shim, but don't know how to remove the original. Does it require a special tool?
A more accurate explanation would be nil on the "no clearance" because there typically is some clearance just so tight a gauge cannot read it. You will need a shim that is small enough to put in the place of that shim to give you an idea of where to start with in sizes for the nil reading. Have fun. And keep it clean. Very clean.
KZ 900-a4
  • vondikka
Re: shims
03 May 2013 00:09
#585380
I have a repair manual and have already removed the cams and bucket on the valve with no clearance. I just need to know how to remove the shim itself
78 KZ650 C2
76 kz400 D3
  • vondikka
Re: shims
03 May 2013 00:13
#585382
My service manual says nothing about how to remove the shim, just a diagram.
78 KZ650 C2
76 kz400 D3
  • Motor Head
  • Motor Head's Avatar
Re: shims
03 May 2013 00:15
#585383
If you have the cam and the bucket already out, you just need a strong magnet for the shim.
  • vondikka
Re: shims
03 May 2013 00:49
#585397
Awesome
78 KZ650 C2
76 kz400 D3
  • vondikka
Re: shims
03 May 2013 00:51
#585398
I'll try that. Hopefully I won't have any problems putting it back together. You guys made it sound kinda scary lol
78 KZ650 C2
76 kz400 D3
