Risk Of Running With Zero Clearance Intake Valves
- mind2find
19 Apr 2013 17:16
Have a KZ750B1 open on top, and just measured all the clearances. The two intake valves have zero clearance (feeler gauge 0.038mm will not fit). There are 275 shims beneath them. Probably need to swap in some 260.
What is the danger of reassembling and starting up the bike like this for a while, until we find new shims?
We are in lockdown in Arlington, MA right now, with time to work on the bike as a productive distraction from the TV.
Thanks.
Thanks.
1976 KZ-750B1 (late model)
1976 KZ-750B1 (early model) Parts Bike
Boston, MA
Boston, MA
- LarryC
Re: Risk Of Running With Zero Clearance Intake Valves
19 Apr 2013 19:16mind2find wrote: Have a KZ750B1 open on top, and just measured all the clearances. The two intake valves have zero clearance (feeler gauge 0.038mm will not fit). There are 275 shims beneath them. Probably need to swap in some 260.
Thanks.
I have a pile of 260's...most common size to remove. Where are you at? How many do you need?
Larry C.
- steell
19 Apr 2013 21:48 - 19 Apr 2013 22:03
Larry, you have a pile of 750 twin 32mm shims? And never told me?
To answer the original question, if you can rotate the bucket/shim with your fingers, then there is at least a little clearance and you probably won't burn a valve. When the motor will no longer idle when hot, then you know the valves are to tight.
Last edit: 19 Apr 2013 22:03 by steell.
The following user(s) said Thank You: jonarmstrong
- mind2find
19 Apr 2013 22:07
LarryC, absolutely! Just outside of Boston (and breathing a huge sigh of relief at the moment). We'd need 2 of them. It's a 1976 KZ750B1, just to be totally specific. I assume they're pretty commonly sized for a lot of the KZ's. Email me at sandsfish [at] gmail [dot] [com] and let me know how much you want for them. Cheers!
Boston, MA
Boston, MA
- bountyhunter
19 Apr 2013 22:38 - 19 Apr 2013 22:41Specified clearance for the 750 twin is 0.5 - 1.0 mm, but many allow up to 1.5 mm maximum. You are liklely between 0 - 0.5 mm now, probably not actually zero. If you have a 275, then you likley need 270 - 265 range.mind2find wrote: Have a KZ750B1 open on top, and just measured all the clearances. The two intake valves have zero clearance (feeler gauge 0.038mm will not fit). There are 275 shims beneath them. Probably need to swap in some 260.
Thanks.
my gauge set goes down to .001" which I think is .025 mm. Might help get the clearance measurement.0.038mm will not fit
Last edit: 19 Apr 2013 22:41 by bountyhunter.
- steell
20 Apr 2013 00:34mind2find wrote: LarryC, absolutely! Just outside of Boston (and breathing a huge sigh of relief at the moment). We'd need 2 of them. It's a 1976 KZ750B1, just to be totally specific. I assume they're pretty commonly sized for a lot of the KZ's. Email me at sandsfish [at] gmail [dot] [com] and let me know how much you want for them. Cheers!
Bad news, the 750 twin is the only Kawasaki that uses that size shims, all the rest are smaller.
I recall reading a post on the Kawasaki Twins forum that one of the imported cars uses the same size shim. Could take a look over there and search for the post.
I'm thinking Larry has a bunch of under bucket 650/750 four shims
- steell
20 Apr 2013 00:39
bountyhunter, I think maybe you misplaced a decimal.
1mm is .040", I'm sure you meant to type .1mm to .05mm
- bountyhunter
20 Apr 2013 02:10Yep, should never do math when I have a headache.steell wrote: bountyhunter, I think maybe you misplaced a decimal.
- LarryC
20 Apr 2013 07:39steell wrote: Larry, you have a pile of 750 twin 32mm shims? And never told me?
Oh Shit :ohmy: ..didn't notice it was the twin...... cancel that offer
Larry C.
- z1wiz
20 Apr 2013 10:45
I have some 32mm shims. Let me know what sizes you want for sure, and I will see if I have them.
Russ
Russ
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
- Phaedrus
01 May 2013 01:32 - 01 May 2013 08:11
Hi Russ - mind2find and I are working on this bike together. After realizing that we were using the wrong valve adjustment chart for these clearances (thanks bountyhunter & steell for tipping me off with those clearance specs!), it looks like we need 3 2.70s (32mm). It turns out that not only were the two intake valves tight at 2.75 each, we've got adjustments to make on the exhaust valves as well. Any chance that you've got three of these laying around?
Thanks!
Thanks!
Last edit: 01 May 2013 08:11 by Phaedrus.
- z1wiz
01 May 2013 11:37
I will look tonight.
The following user(s) said Thank You: Phaedrus
