Risk Of Running With Zero Clearance Intake Valves
  • z1wiz
  • z1wiz's Avatar
Re: Risk Of Running With Zero Clearance Intake Valves
02 May 2013 21:53
#585338
Well, I didn't have any that size.
Sorry,
Russ
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
  • Motor Head
  • Motor Head's Avatar
02 May 2013 22:24 - 02 May 2013 22:35
#585347
steell wrote:
mind2find wrote: LarryC, absolutely! Just outside of Boston (and breathing a huge sigh of relief at the moment). We'd need 2 of them. It's a 1976 KZ750B1, just to be totally specific. I assume they're pretty commonly sized for a lot of the KZ's. Email me at sandsfish [at] gmail [dot] [com] and let me know how much you want for them. Cheers!
Bad news, the 750 twin is the only Kawasaki that uses that size shims, all the rest are smaller.
I recall reading a post on the Kawasaki Twins forum that one of the imported cars uses the same size shim. Could take a look over there and search for the post.
I'm thinking Larry has a bunch of under bucket 650/750 four shims :)
I believe it would be the FIAT 124 motor. FIAT Stands for Fix It Again Tony
Z1enterprises.com has some 32mm shims also.
Last edit: 02 May 2013 22:35 by Motor Head.
The following user(s) said Thank You: Phaedrus
  • Phaedrus
  • Phaedrus's Avatar
03 May 2013 10:08
#585415
Okay, thanks for looking. I'll check out Z1 as steell suggested.
1976 KZ-750B1 (late model)
  • steell
  • steell's Avatar
03 May 2013 15:23
#585456
Phaedrus wrote: Okay, thanks for looking. I'll check out Z1 as Motor Head suggested.
Fixed that for you, I can't take credit for a suggestion made by someone else. :P
