installing fresh pistons and rings
  • steell
  • steell's Avatar
Re: installing fresh pistons and rings
05 Apr 2013 19:02 - 05 Apr 2013 19:02
#580753
Attention engine builders!! Never waste your time and money doing dyno pulls until the compression stops building ever again! Just throw in a set Of MTC pistons with their magical rings that seal instantly on start up!! Amazing!!!!
Last edit: 05 Apr 2013 19:02 by steell.
The following user(s) said Thank You: LarryC
  • dbc92s10
  • dbc92s10's Avatar Topic Author
05 Apr 2013 19:24
#580757
steell wrote: Attention engine builders!! Never waste your time and money doing dyno pulls until the compression stops building ever again! Just throw in a set Of MTC pistons with their magical rings that seal instantly on start up!! Amazing!!!!
well i figured id just let you know what mtc told me to do, they also told me to set my ring gaps at .0085 per inch of bore wtf yeah right :woohoo: and if you need some of those amazing rings steell let me know i got the hook up :woohoo: :woohoo:
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
  • bountyhunter
  • bountyhunter's Avatar
05 Apr 2013 20:05 - 05 Apr 2013 20:06
#580764
dbc92s10 wrote: they also told me to set my ring gaps at .0085 per inch of bore wtf yeah right
That's twice what everybody else says. :P
Last edit: 05 Apr 2013 20:06 by bountyhunter.
  • LarryC
  • LarryC's Avatar
05 Apr 2013 23:12
#580780
Let's go there next :woohoo:
Larry C.
  • LarryC
  • LarryC's Avatar
05 Apr 2013 23:15
#580781
wireman wrote: The 1940s thing was a joke,for those that aren't smart enough or too serious to get it I don't know what to tell ya! :sick: :woohoo:
The guy I learned the dry piston trick from way back when has been building flat head fords since the 40s though,and he still pours his own babbit bearings in engine blocks.
Hes got to be pushing 90 and was stil driving his old rat rod 31 ford pick up with a hot rodded flat head when I saw him last summer. :)
Attachment download.jpg not found
Larry C.
  • steell
  • steell's Avatar
06 Apr 2013 01:32
#580793
My sarcastic reply was directed against MTC, not you, tried to make it obvious :)
  • zed1015
  • zed1015's Avatar
06 Apr 2013 06:25
#580805
dbc92s10 wrote: well i figured id just let you know what mtc told me to do, they also told me to set my ring gaps at .0085 per inch of bore wtf yeah right
I think you must have spoke to the tea boy or Janitor :lol:
MTC use the same XA/XC etc rings as wiseco and recommend the same gapping method and specs.
See MTC's site for more info here ... www.mtceng.com/technical-information/piston-kit-installation
  • wireman
  • wireman's Avatar
06 Apr 2013 08:33
#580815
So how about some progress pictures? :)
  • dbc92s10
06 Apr 2013 11:47
#580845
One step forward, then three backward. i had to send pistons back to manufacturer. three of the pistons the second ring groove was not cut deep enough for the rings they were 1/64 to shallow.its always something :unsure:
81 ltd1000
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
  • wireman
  • wireman's Avatar
06 Apr 2013 12:36 - 06 Apr 2013 12:45
#580850
:sick:
What did mtc have to say about it? :blink:
Ive always wondered how they keep the prices on mtc so much lower than wiseco,Im wondering if they should dump more money into quality control and packaging.
Id ship the cylinder with the pistons to them so they can make to get the clearances right for the new pistons,unless they want to put your pistons on a lathe and re cut the grooves.
No sense in you having to pay to have cylinder rehoned to match different pistons. ;)
Last edit: 06 Apr 2013 12:45 by wireman.
06 Apr 2013 12:42
#580852
That enables them to seat faster. :woohoo:
  • wireman
  • wireman's Avatar
06 Apr 2013 12:48
#580853
You have to be able to get the pistons to fit in the bores with the rings first before you can worry about seating them! :laugh:
