installing fresh pistons and rings
- dbc92s10
03 Apr 2013 22:17
fresh 74mm bore, new mtc pistons and rings question is; should i oil the pistons and rings, or install them dry. i would think dry would cause excessive wear :dry:
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
- 4TheKZ1000
Re: installing fresh pistons and rings
03 Apr 2013 22:20 - 03 Apr 2013 22:26
wet....check with mtc on what to use....oil, assembly lube or other type.
Last edit: 03 Apr 2013 22:26 by 4TheKZ1000.
- wireman
03 Apr 2013 22:28
I was taught to put them in a clean dry bore to help seat the rings,of course the 1940s was a while back. :laugh:
You crank it over first with no plugs in motor to check everything out,it doesn't take long to get oil slopped up there once the motor has been cranked over.
Alright let the debate begin! :woohoo:
Attachment popcorn_2013-04-03.gif not found
- Nebr_Rex
03 Apr 2013 22:43 - 04 Apr 2013 09:41wireman wrote: I was taught to put them in a clean dry bore to help seat the rings,of course the 1940s was a while back.
That would make you our oldest member at over 80 years old. :woohoo:
Don't break a hip gramps. :whistle:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: 04 Apr 2013 09:41 by Nebr_Rex.
- justfreaky
03 Apr 2013 22:48
Hmmm. Born 1965.
I have socks older than Wireman.
Alright!!!! Not proud of that!
1980 Kawasaki KZ1000 B4 LTD
1981 Suzuki XS1100 Special
1984 Honda VF500
1984 Honda VF500
- wireman
03 Apr 2013 22:52Attachment checkingthemail.jpg not found
Hang on ,let me see if my new pacemaker came in the mail from APE today! :woohoo:
- elfmagic17
03 Apr 2013 22:55
I always rub a little oil all over each cylinder before installation. I use straight non-detergent 30w for break-in with excellent results. Kind of hard to get straight 30 now though. (Thanks Tree Huggers !)
Kenny Hicks
74 Honda CB550
74 Honda CB550
- justfreaky
03 Apr 2013 23:28
Nice scooter Wireman!
I have always coated rotating parts with oil or lube of some sort. More damage can happen in the intitial cranking of a dry engine.
My .02
My .02
1984 Honda VF500
1984 Honda VF500
- wireman
03 Apr 2013 23:34
That's only on piston rings,I always slop cam shafts/buckets and bearings with assembly lube before installing
- Powerstroke_fan
04 Apr 2013 08:08
I was told when i built my motor that i could put the piston and rings in dry to make the rings seat fast. I was told by a very reliabale source thats what alot of the drag racers do.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- LarryC
04 Apr 2013 08:36 - 04 Apr 2013 08:44
One of the above posts is an absolute lie....You figure it out
Shouldn't be difficult.
If you correctly prep the block.......
Light coat of oil on the skirts.
Oil the bores up in about 1 inch, lightly to assist assembly.
After the block is on, turn the engine over several times, then bring each pair of cylinders to BDC and wipe any excess oil out.
Extra oil will just blow in the exhaust ports and start the carbon process. Modern, hard coated cylinders are generally suggested to use dry assembly BUT you don't have one of those...It's an OLD Kawasaki...keep that in mind.
Or you could split the difference and do each hole a different way :laugh:
Make sure you don't overlap the oil ring.
Larry C.
Last edit: 04 Apr 2013 08:44 by LarryC.
- wireman
04 Apr 2013 09:35
That's why its called a debate.
