installing fresh pistons and rings
- gdprather
Re: installing fresh pistons and rings
04 Apr 2013 10:18
so so funny lmao.
1985 Kawasaki Vucan vn700A1
1983 Kawasaki KZ1100D2 Spectre
- wireman
04 Apr 2013 10:18
The 1940s thing was a joke,for those that aren't smart enough or too serious to get it I don't know what to tell ya! :sick: :woohoo:
The guy I learned the dry piston trick from way back when has been building flat head fords since the 40s though,and he still pours his own babbit bearings in engine blocks.
Hes got to be pushing 90 and was stil driving his old rat rod 31 ford pick up with a hot rodded flat head when I saw him last summer.
- 4TheKZ1000
04 Apr 2013 10:21
you dont grab your 1 inch killer with a dry hand do you Wireman?
- wireman
04 Apr 2013 10:41 - 04 Apr 2013 10:56I tried using assembly lube on it,but it was too damn messy! :sick: :woohoo:4TheKZ1000 wrote: you dont grab your 1 inch killer with a dry hand do you Wireman?
Its only got an inch of stroke,but its got a 4 1/8" bore! :woohoo:
Last edit: 04 Apr 2013 10:56 by wireman.
- bountyhunter
04 Apr 2013 15:16I oiled everything during assembly. I didn't have any fancy assembly lube so I used a 50-50 mix of STP and Valvoline motor oil to coat things.dbc92s10 wrote: fresh 74mm bore, new mtc pistons and rings question is; should i oil the pistons and rings, or install them dry. i would think dry would cause excessive wear :dry:
- 4TheKZ1000
04 Apr 2013 15:25 - 04 Apr 2013 15:26
I thought seating rings or breaking-in was first 500 miles riding bike not dry cylinders and rings chewing on eachother.....just my thought.... :whistle:
Last edit: 04 Apr 2013 15:26 by 4TheKZ1000.
- zed1015
04 Apr 2013 16:01
MTC recommend DRY assembly (no oil on the bores) to aid quick bedding in and a resultant higher compression.
Also use a straight mineral oil for the first runs.
Just lube the skirts below the rings as they enter the bores.
It is now a known fact that the main bedding in period is in the first 20 miles.
The 500 mile + period was invented by mass manufacturers to cover their backs against inconsistant tolerances in other areas of a new engine,crank shells etc.
- Powerstroke_fan
04 Apr 2013 17:42 - 04 Apr 2013 17:44
Thanks for the reply zed. I know that i was told i could assemble them like that ( i didnt tho). The guy that told me that builds motors and knows his motors very very well. And is very well known for his quality work (anyone following my build will know who iam talking about)
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 04 Apr 2013 17:44 by Powerstroke_fan.
- turboguzzi
04 Apr 2013 18:12
udo gietl (who knows here who is he WITHOUT googling?
) was very much for dry assembly. and his bikes won a few races
and definitely dont baby it while breaking it in, actually start loading the motor right away from the first start, avoid running it standing still, it will do nothing for good ring seating.
best if you can run it in on a dyno where you can do controlled pulls.
- racer54
04 Apr 2013 18:28
Brother-in-law was always told by experienced engine builder after fresh build to start motor and put a load on it. Rings seat in first few miles. So he ran it hard like he planned on running bike...and he never had any problems. I have always put a light coating on piston assembly and cylinders for assembling purposes. Started motor up and run it through rpm range carefully. Watched engine smoke to see if it cleared up quickly...Never had any problems doing it this way except when an oil ring got over-lapped. Smoke never did clear up from that... :whistle: Was on start of trip and had to turn back and remove cylinder and found the ring problem. Re-assembled motor and headed back out the next day...been running great for last 20+ yrs and still no smoke... But have also been told to put it together dry, start bike up and abuse it...rings seat within first couple miles. If they aren't seated by then they won't...seems to work both ways to me...
- LarryC
04 Apr 2013 18:42 - 04 Apr 2013 18:45racer54 wrote: Brother-in-law was always told by experienced engine builder after fresh build to start motor and put a load on it. Rings seat in first few miles. So he ran it hard like he planned on running bike...and he never had any problems. I have always put a light coating on piston assembly and cylinders for assembling purposes. Started motor up and run it through rpm range carefully. Watched engine smoke to see if it cleared up quickly...Never had any problems doing it this way except when an oil ring got over-lapped. Smoke never did clear up from that... :whistle: Was on start of trip and had to turn back and remove cylinder and found the ring problem. Re-assembled motor and headed back out the next day...been running great for last 20+ yrs and still no smoke... But have also been told to put it together dry, start bike up and abuse it...rings seat within first couple miles. If they aren't seated by then they won't...seems to work both ways to me...
Yepper..... and it's because when do things you use......come on now...holler it right out.... COMMON SENSE :woohoo:
Larry C.
Last edit: 04 Apr 2013 18:45 by LarryC.
- dbc92s10
05 Apr 2013 18:29
called mtc today and was told to install pistons completely dry which would make rings seal instantly upon start up
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
