- Thank you received: 14
How get the starter clutch off from a KZ 1100 ??
- Arnold
You know this...but I dont
Whats the best way to get the fly whell off my KZ 1100 ?
Am I on the right way here ?
Need a larger puller...or is there a better way ?
Check out my project at:
kzrider.com/forum/11-projects/550823-ret...100-82-goes-z1-clone
- wireman
- Thank you received: 299
You might want to put a piece of copper or lead between the jaws on that vise and the counter weights on that crank,just saying :blink:
- donthaveakawman
- Visitor
also I noticed there are little bolts in there did you see those?
- Kraz1
- LarryC
donthaveakawman wrote: that little puller is never going to get the clutch basket off your crank, go return it and get a bigger one.
:blush: Rotor Don... Clutch basket is on the end of the transmission input shaft buddy But you're right...that's really not the best tool for the job.
Larry C.
- Kraz1
The Little Bolts are in your Neck Franken Don.
- Motor Head
- Thank you received: 391
- donthaveakawman
- Visitor
- Thank you received: 2098
- wireman
- gpz1170
- Thank you received: 10
They can sometimes be difficult. Good luck,
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- gpz1170
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
