camchain and mystery part?
  • davem
  • davem's Avatar Topic Author
Re: camchain and mystery part?
04 Feb 2013 18:33
#570759
I found another cam chain guide down in the oil pan when I dropped it.
See picture below.
Any idea what causes them to break.
Should I be concerned of damage to the engine fron this.
Attachment 20130204_132732.jpg not found
Attachment 20130204_132706.jpg not found
Attachment 20130204_132204.jpg not found
Attachment 20130204_132425.jpg not found
Attachment 20130204_132209.jpg not found
Attachment 20130204_132223.jpg not found
1979 Kz1000 B3 LTD
1997 Kawasaki police 1000
1985 kz1000p4 project-sold
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
04 Feb 2013 22:44 - 05 Feb 2013 22:11
#570804
I imagine a loose cam chain. But doesn't your model year have an automatic chain tensioner? But even an automatic one could be getting stuck or have a weak spring.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 05 Feb 2013 22:11 by KZJOE900. Reason: substitute wrong word
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
05 Feb 2013 15:27
#570896
Is it just the picture, or is the oil pump screen mostly clogged? It seems like the last person in that engine went hog wild with the RTV sealer. When reassembling mine I did an experiment. No RTV. Just a very light film of water proof grease on the cylinder block base gasket. Went dry with the head gasket. And used Permatex Cooper gasket spray on the pan, tensioner body and valve cover gaskets. On the valve cover gaskets I reused the old gasket (which leaked), just to see how this cooper spray treatment worked. I hasn't leaked. But my goal is to see how easy it is to take these gaskets off once I go in there again. Aside from not getting any leaks (which I have not), which method is easiest for the gasket to come off and clean off.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • davem
05 Feb 2013 21:24
#570946
Thanks!
1979 Kz1000 B3 LTD
