camchain and mystery part?
  • davem
  • davem's Avatar Topic Author
03 Feb 2013 21:22 - 03 Feb 2013 21:29
#570621
I have a barn find 79 b3 kz1000 project. 45kmiles.
Pretty beat up. Top of the engine is pre79 bottom is 79.
Basically they removed the emissions stuff.
I am rebuilding the motor at this time here is the questions?
First when I removed the head and than pulled up the second part and put a long flexable tool with a magnet on the end through to hold up the cam chain. After getting the engine components off I went to pull out the magenet after tieing up the cam chain of coarse there was a part on the magnet I dont know where it came from.
I have the repair manual and I can't find the part in there. I watched several youtube videos and its not in there.
I am including pictures of the part.
In the pictures youll see the orange handle magnet tool I ran between the engine.
One other q uestion I have is about the cam chain. If im holding the chain up tight should it slip when I turn the engine over by 17mm bolt under timing cover?
Attachment 20130203_151642.jpg not found
Attachment 20130203_151651.jpg not found
Than you
Attachment 20130203_151539.jpg not found
Attachment 20130202_191549.jpg not found
Attachment 20130202_192459.jpg not found
Attachment 20130202_191609.jpg not found
Attachment 20130202_191537.jpg not found
1979 Kz1000 B3 LTD
1997 Kawasaki police 1000
1985 kz1000p4 project-sold
Last edit: 03 Feb 2013 21:29 by davem.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: camchain and mystery part?
03 Feb 2013 21:26 - 03 Feb 2013 21:34
#570624
first pic is a cam chain guide.....73-80 engines.
Part number 12 (see below link) - Kawasaki Part # 12053-019
www.cmsnl.com/kawasaki-1978-kz1000-a2a-k...t/66349.html#results
Last edit: 03 Feb 2013 21:34 by 4TheKZ1000.
  • z1kzonly
  • z1kzonly's Avatar
03 Feb 2013 21:32
#570625
Wow. That engine is pretty whoopped up! Those are higher compression aftermarket pistons.
That part is the cam chain guide that sits in the cylinder block to the front of engine. Directly across from ther chain adjuster boss. It is held in place with a 6mm thread phillips head screw.
Who ever built that engine did not put any lock tight agent on that screw. Thats why alot of guys strip that phillips screw trying to take it out.
So there is also a screw in the bottom. Unless that bracket broke? Is the little 6mm hole intact or lock cracked, broke in half? Opposite side of your picture?
Take that engine out and dismantle it!
  • z1kzonly
  • z1kzonly's Avatar
03 Feb 2013 21:34
#570626
OK, I did not see your first pics. Yes that part broke off!
  • davem
03 Feb 2013 21:45
#570628
z1kzonly wrote: Wow. That engine is pretty whoopped up! Those are higher compression aftermarket pistons.
Thanks for your response. I was trying to decide if i was going to dismantle the rest of the engine.
I guess I have my awnser.
How do you know those are aftermarket pistons and not stock? How do I know what rings to get for it if its not stock?
Thanks again for your help!
1979 Kz1000 B3 LTD
  • 4TheKZ1000
03 Feb 2013 21:49 - 03 Feb 2013 21:52
#570630
extended dome on top of piston...the dome is used to raise compression.
stock pistons dont have dome. (see pic below)
Last edit: 03 Feb 2013 21:52 by 4TheKZ1000.
  • davem
03 Feb 2013 21:51
#570631
4TheKZ1000 wrote: first pic is a cam chain guide.....73-80 engines.
Thanks do you know wher I can find a picture of that on the motor? So I can see where ist goes exactly.
1979 Kz1000 B3 LTD
  • 4TheKZ1000
03 Feb 2013 21:59
#570632
do you have a quality factory kaw manual?
If not.....you need to get one.
  • davem
03 Feb 2013 22:04 - 03 Feb 2013 22:09
#570634
4TheKZ1000 wrote: do you have a quality factory kaw manual? If not.....you need to get one.
I Have the one for the z900 in the file base here. and I have a Old Old Klymer. This Motor is so custom its tough I dont know which one to get. I fear Ill buy one and it will be the wrong one and I ll just have to buy another. For instance the part in the link you provided earlier that obviously is in my 79 bike is from a 78 a model according to that sight.
Any sugestions? There are a couple on ebay. Just dont know which one.
1979 Kz1000 B3 LTD
Last edit: 03 Feb 2013 22:09 by davem.
  • 4TheKZ1000
03 Feb 2013 22:05 - 03 Feb 2013 22:07
#570635
Sorry about poor pic quality. Goes in front of cylinder head....can only go one way, only one screw hole.
Attachment IMG0692A.jpg not found
Last edit: 03 Feb 2013 22:07 by 4TheKZ1000.
  • davem
03 Feb 2013 22:19
#570637
Thanks again.
Nice bike BTW. I checked out your bike pics and that is one sweet ride.
1979 Kz1000 B3 LTD
  • 4TheKZ1000
03 Feb 2013 22:24
#570638
Thanks, If we can help let us know..... B)
