- Thank you received: 83
Oil Cooler Questions.
- 4TheKZ1000
- Visitor
26 Jan 2013 14:47 - 08 May 2013 00:18 #569373
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Oil Cooler Questions.
Both my fittings have 1/4 NPT threads. Will use these AN fittings.
Last edit: 08 May 2013 00:18 by 4TheKZ1000.
- Powerstroke_fan
27 Jan 2013 11:58 #569504
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Oil Cooler Questions.
i personally bought a derale oil cooler havent installed it yet tho. but it looks like its bigger than the one in the pic
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- 4TheKZ1000
- Visitor
29 Jan 2013 19:41 #569824
by 4TheKZ1000
Just an overlay of whats going on.
Earls 13 row oil cooler. 8.25" x 4" x 2"
6-AN fittings only....no barb fittings.
6-AN hose ( 3/8 inch eqv )
After much thought and running lines several different ways, running oil lines though neck area and under tank coming down between #2 and #3 carb boots seems the way to go.....very clean way to plum without hose showing.
does anyone feel this is a problem?
I have one line plumbed and need a different fitting for other.
I will post pics later.
Thanks for looking....
