- Thank you received: 299
Oil Cooler Questions.
- 4TheKZ1000
- Visitor
Which fitting pumps the oil to the cooler and which one is the return line?
Its a pre-J engine.
Thanks.
- wireman
- Old Man Rock
- Thank you received: 225
This 3/8ths line will feed into either end of the oil cooler.
The return line from the other end of the cooler will go to the upper case fitting behind the cylinder (right side of rear engine, oil pressure screw tube)thus feeding oil back into the system being passed up into/through the rear cylinder studs up to the head.
One with thread for oil switch, mounts to top of engine case.
Definitely use new O-rings... As me how I learned this.... (See image) :ohmy: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- 4TheKZ1000
- Visitor
- 4TheKZ1000
- Visitor
Looks like the other fitting has a bigger thread size......anyone know this size?
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 4TheKZ1000
- Visitor
Old Man Rock wrote: 3/8ths line on both cooler feeds into barbed fittings.... Same....
Im going to run AN fittings on mine....so need to remove barb fittings.
- pete greek1
- Thank you received: 185
- Old Man Rock
Under engine case seemed a PITA for oil changes and possible punctures not to mention added heat off exhaust.
Over engine also seemed a PITA due to heat on lines, kind of defeats the purpose of an oil cooler (to cool the oil down)....
Here's on my last build.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2098
- pete greek1
- wireman
Im wondering about that billet aluminum motor mount,what else is patton trying to hide? :laugh:Patton wrote: Another option, cheap, durable, subdued.
