This can't be good.
  • zukdave
  • zukdave's Avatar Topic Author
Re: This can't be good.
26 Jan 2013 01:34
#569322
Cool I get a hall pass on this then ?
Oh and the real cool part in my hand
for a $100 buck's.
Another $100 for a gasket set and $50?
for odd's and end's plus BEER
so around $250 to fix it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
26 Jan 2013 01:45
#569324
wow its lookin good
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • wireman
  • wireman's Avatar
26 Jan 2013 01:53
#569326
Nice work! B)
  • zukdave
26 Jan 2013 18:01
#569386
I might take the case back to Mac.
The more I think about it Mac was pointin and
mumbling something about it'd be eazy to remote filter it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • turboking
  • turboking's Avatar
26 Jan 2013 18:13
#569388
nice repair :woohoo:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • bluezbike
  • bluezbike's Avatar
26 Jan 2013 19:01
#569393
Very nice repair. :woohoo: Remote filtering? Now that sounds like a very good idea especially on a drag bike. I have never seen or heard of painting the inside of the motor, could you please elaborate on the benefits and even what type of paint...how it is applied etc.?
Many thanks
79 KZ 1000 LTD
  • lushbaugh
26 Jan 2013 19:31
#569402
great idea however id check oil pressure operation range and use a common import small filter. if its a low pressure motor like the kz1000 i wouldnt as it may not flow enough but i think your motor used shell bearings opposed to the needle bearings so you may have the oil flow and pressure to pull it off. just a thought.
  • zukdave
26 Jan 2013 19:56
#569409
Car guy's paint the inside to help the oil drain
back to the pan.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • Old Man Rock
  • Old Man Rock's Avatar
26 Jan 2013 20:56
#569413
Beautiful weld.... LUV a good welder/job.... B)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • zukdave
26 Jan 2013 21:14
#569415
OMR I was real happy with it.
Lush we have a small remote filter setup
at work for the hydrostatic drives on the big Gravely
stuff that will work good.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • zukdave
13 Feb 2013 01:36
#572200
Rob at Z1 sent me these so now I can
put my motor back together.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • Old Man Rock
13 Feb 2013 07:12
#572220
Dave, Do yourself a HUGE favor....
Had the exact same Z1 kit so... don't use those valve oil seals (ask me how I know :whistle: )... All other gaskets no issues. Bastards will start leaking on ya within 1k miles. Ended up having to go back in on my first build and replacing.
Larry C warned me but did I listen, nope and had to learn the hard way of course... :pinch: :laugh:
Spend a little extra cash and get the APE seal kit for which I just ordered @ $18 for 8 pack or Viton @ Pit Stop for $25....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
