This can't be good.
- 4TheKZ1000
Re: This can't be good.
13 Jan 2013 16:28
Im getting a low profile cover with the flush fit bolt....this is more than a bit disturbing.
- guitargeek
13 Jan 2013 16:35
I'd get a longer ramp, too.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- zukdave
13 Jan 2013 17:15guitargeek wrote: I'd get a longer ramp, too.
I'm gonna build a trailer thats custom fit for my bike.
I have some plans I drew up for an air bagged trailer that will
lower and lay the end of bed on the ground and need no ramp.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- guitargeek
13 Jan 2013 17:57
Nice!
- zukdave
20 Jan 2013 11:53
I got the motor out yesterday and started opening it up.
I think this is one of if not the cleanest motor I,ve ever opened up.
And whats up with it being painted or coated black in side ?
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- wireman
20 Jan 2013 13:06
helps seal castings and aids oil flow back to pan,I still paint the inside of iron blocks with that nasty ass glyptol paint for that reason.
They paint inside of Harley castings to help seal pin holes in the castings ,compared to those nasty Harley castings the kaw castings are perfect out of the box! :woohoo:
- zukdave
20 Jan 2013 14:07
I know why it's done just didn't think the factory did it.
Well I'm off to split the case's and go see the tig guy.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Old Man Rock
20 Jan 2013 19:23
Damn it... every time I see that image of the ripped oil filter galley I just cringe.... :pinch:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- APE Jay
- zukdave
20 Jan 2013 20:20
Jay I called your place last Thursday
and the guy I talked to said he had no idea
who made a low pro. cover for the small four's.
Now if you know better call me at
512-902-5311 I'll buy two.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
20 Jan 2013 20:48
Ok got the case's split and wanted to cry
it's just to new of a motor inside to have to open up.
The pan as it came off with no cleaning.
The crank.
Look's like maybe a little factory back cut here ??
The crank.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- wireman
20 Jan 2013 21:01
Well atleast it didn't come apart for something worse ,that's fixable.
Im sure you already know this but Id suggest have cases bolted together and empty cylinder and head bolted down on the cases when he welds it to protect it from warping the cases.
