This can't be good.
- zukdave
Re: This can't be good.
13 Jan 2013 12:19wireman wrote: Time to shove a kz1000 motor in there,lot less money! :sick:
Attachment handface_2013-01-12.gif not found
Shipping to 78753 ?
I'll put your name on it for the donated motor.
Going to try to pull the motor today and spilt the case's
Buddy said he should be able to tig it back together so we'll see.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Old Man Rock
13 Jan 2013 12:22
I feel your pain... Totally SUCKS! :pinch:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- z1wiz
13 Jan 2013 12:29 - 13 Jan 2013 12:37
Seen this before! A friends pro street bike lowered too much snagged it pulling in a driveway. Should have had the APE low profile oil filter cover. It did after I changed the cases.
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
Last edit: 13 Jan 2013 12:37 by z1wiz. Reason: error
- 4TheKZ1000
13 Jan 2013 13:01
Never thought or knew about this being a weak point....were on notice now.... :ohmy:
- les holt
13 Jan 2013 13:02
I seen one broke, pulled bar off protire bike and did launch, wasn't the mans brightest moment! Bike slammed into the street. :sick:
I vote going 1000 also.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- Kitten Tooth
13 Jan 2013 13:51
Time to crack out the JB weld...
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- wireman
13 Jan 2013 15:32What area is that zip code connected to?zukdave wrote:wireman wrote: Time to shove a kz1000 motor in there,lot less money! :sick:
Shipping to 78753 ?
- wireman
13 Jan 2013 15:37I always had to steer my 1327 around speed bumps to avoid dragging my pipe with the 10 1/4" shocks,Id always lift the ass end anytime I had to load it into a truck or trailer4TheKZ1000 wrote: Never thought or knew about this being a weak point....were on notice now.... :ohmy:
- 4TheKZ1000
13 Jan 2013 15:51
The guy who designed this oil plate and bolt setup is a dumbazz. He needs to have some bamboo slivers shoved under the finger nails.
- zukdave
13 Jan 2013 15:54
Wireman it's Austin TX.
Come on down we can ride all year if
the oil stays in the motor
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Powerstroke_fan
13 Jan 2013 15:55
Ya my bike will sit up decently after its all together but after seeing this i think i might invest in a low profile set. Sorry to hear bout your bad luck. I hate it when stupid stuff like that happens.
1977 KZ 1000 work in progress
- zukdave
13 Jan 2013 16:07
It wasn't because the bike set's low
it's got 5" under the bolt on flat ground.
The break over angle coming up the ramp and me pissed at
the drunk G/F and coming up the ramp a little to fast is what caused it.
I think if it had a button head and not the hex
it would have slid over the lip and not broke.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
