Cam Timing Problem!!!!
- 1980classic
29 Dec 2012 21:18
1980 Z1 classic 14,000 miles with working FI. Recently installed new pistons and rings, and dyna 3ohm coils and wires, removed resistor, installed pogue adjustable fpr. Valve job done by reputable local shop. Put it all back together. Motor starts up immediately, but seems to be out of time with intermittent backfire through throttle bodies and then dies. All plugs are black, cannot get a consistent idle. Followed the directions step by step several times, exhaust mark => aligned with head surface, counted 28 pins from next link pin, the intake mark is aligned with valve surface. Intake looks about 1 tooth off to me, but I am unsure. If I go back one tooth the gear marks on the intake will not be inline. All pics taken at TDC 1/4. I know this has been covered but I still need more clarification
- 4TheKZ1000
Re: Cam Timing Problem!!!!
29 Dec 2012 23:34 - 29 Dec 2012 23:40
Are thoose factory timming lines on cam sprockets or did you line up cam timming (T-1-4) and self scribe lines on cam sprockets before taking engine down?
Last edit: 29 Dec 2012 23:40 by 4TheKZ1000.
- 1980classic
30 Dec 2012 00:45
I assume those are the factory lines. I am the second owner and those were the marks present when I removed the cover.
- trianglelaguna
30 Dec 2012 01:06
i always use the marks on the lobes on the outside when R&Ring cams
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- 1980classic
30 Dec 2012 01:25
What marks on the lobes? I see some lines on the very ends of the cams.
- 4TheKZ1000
30 Dec 2012 01:51 - 30 Dec 2012 02:041980classic wrote: What marks on the lobes? I see some lines on the very ends of the cams.
Tri is taling about deep groove in the cam end 180 deg of lobe. The cam timming looks correct but is it timmed to crankshaft correct.....was picture taken a t-1 4
Could ignition timming be 180 out? Ive heard of that.....point plate installed wrong?
Last edit: 30 Dec 2012 02:04 by 4TheKZ1000.
- 1980classic
30 Dec 2012 02:09
bike has electronic ignition. All pictures were taken at tdc 1/4. bike starts really easy, but runs rough with the back fire through the throttle bodies. When the bike is started it timing mark is place on the F mark. With the timing light firing the f alignment is not constant, it flutters back and forth. Only thing that makes me think I am 1 tooth off on the intake is from other pics the 28th link is more at a 12 o'clock postion
- 4TheKZ1000
30 Dec 2012 02:14 - 30 Dec 2012 02:151980classic wrote: bike has electronic ignition. All pictures were taken at tdc 1/4. bike starts really easy, but runs rough with the back fire through the throttle bodies. When the bike is started it timing mark is place on the F mark. With the timing light firing the f alignment is not constant, it flutters back and forth. Only thing that makes me think I am 1 tooth off on the intake is from other pics the 28th link is more at a 12 o'clock postion
if back firing out of carbs then intake is open to long.....ignition happening while intake valve open
Last edit: 30 Dec 2012 02:15 by 4TheKZ1000.
- 1980classic
30 Dec 2012 02:35
think i will try to move the intake counterclockwise one tooth.
- 4TheKZ1000
30 Dec 2012 02:39 - 30 Dec 2012 02:401980classic wrote: What marks on the lobes? I see some lines on the very ends of the cams.
the hole and 4 lines are just where the cam blank was chucked up in a lathe....they mean nothing. the grove in the end of cam is the area im talking about.
Have you checked the valve clearance.....this could be it......need to check them.
Last edit: 30 Dec 2012 02:40 by 4TheKZ1000.
- Roadflyer
30 Dec 2012 02:43
So, a valve job was done but were the valve clearances adjusted? Perhaps you have valves with no clearance after the valve job.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- 1980classic
