- Thank you received: 13
How easy is it to bugger a valve?
- Roadflyer
ebouwman wrote: I'd already swapped the shims on the suspect valve so I can't be sure how big of a change, but it looks like it gained about 0.03 mm or therabouts. I turned the engine by hand though and looks like I'm pissing air out of that valve on the compression stroke... so ya...
@Roadflyer the cams were good in relation to eachother, just not in relation to the crank.
Never thought about it but can the piston top get damaged ever?
It Takes a running engine to damage a piston.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- nads.com
- Thank you received: 20
the intake and exhaust. Then take off head, out those valves, check the
seats, guides, new seals in, lap, pressure test them ALL>
- ebouwman
nads.com wrote: Use the air leakdown test and listen for which valves are bent through
That may have been good advice yesterday morning...
#1 and 4 were getting weak compression and when the head came off I saw that 1 and 4 had lots of carbon build up so we kept on disassembling and saw that the 1 and 4 pistons didn't have offset rings while 2 and 3 where offset correctly which may explain the carbon build up a bit.
So we may have gone overboard, but we've got quite a long winter here so I've got till may before I even think about putting it on the road.
- chonus
- Thank you received: 8
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
- chonus
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
