How easy is it to bugger a valve?
- ebouwman
So my question is... how likely is it that I've bent a valve?
I don't really want to pull the head just to inspect the valves, so I'm curious if anyone has any experience with bending valves. I don't have the cams back in so i haven't done any sort of compression test as of yet, just looking for advice.
- wireman
- Thank you received: 299
If both cams are out you could blow some compressed air down each splug plug hole and listen for it coming out intake or exhaust.
If you dinged it really good you might notice difference in bucket height in the bore
- Motor Head
- Thank you received: 391
- Motor Head
EDIT: Wiremans quicker.
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- APE Jay
- Banned
- Thank you received: 58
- steell
- ebouwman
I don't have an air compressor at my place, but I'll see about that tool that goes into the spark plug to test compression and I'll check the clearance.
I was really hoping to not have to pull the head and swap out valves but I'll see...
- ebouwman
steell wrote: If you heard a clunk then you bent valves. It takes very little to bend them.
Ya I think you're right.
- Roadflyer
- Thank you received: 13
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- ebouwman
@Roadflyer the cams were good in relation to eachother, just not in relation to the crank.
Never thought about it but can the piston top get damaged ever?
- mick z1a
- Thank you received: 11
