- Thank you received: 1
kz750 ltd 1981 cam chain rattle
- steelhorseangel
- ad@wildlifeartist.plus.com
03 Jan 2013 07:42 #565673
by steelhorseangel
Angel
Restore, Wrench & Ride!
Brought up with Dad, brother, all riders!
Our Dad (Eric) taught us both simple mechanics
before he went to the happy hunting ground, too soon (44)
My KZ is now called Eric and he will ride and protect me!
x God Bless x
Replied by steelhorseangel on topic kz750 ltd 1981 cam chain rattle
hi mh and everyone else!
happy new year.
thanks for your reply!
i went to see a friend who is a
dedicated motorcycle mechanic.
i played the starting problem video
to him and he asked about the fuel tap.
he suggested that the engine is newish.
it has only done 6,800 miles. he thinks
that the pingel tap has filled the carbs bowels
and created a hydaulic lock to happen.
i've sinced checked the bowels and they were full.
what i did was user error 'doh'. i attempted
to start the bike in the cold. the fuel had gone icy
and i used valvolene fst to stop the icing.
the fuel tap was turn on and off to prime.
as the bike made the terrible start up noises.
i sorted one out with the ape tensioner.
the final noise was a 'hydraulic lock'.
i drained the unused fuel from the 4 bowels and
the start up noise has now gone!
a big lesson learnt. i was spoilt in the
past with a modern bike with fuel injection!
many thanks for your help!
kind regards
angel
happy new year.
kind regards
angel
Angel
x God Bless x
- Motor Head
- Thank you received: 391
03 Jan 2013 10:03 #565677
by Motor Head
Replied by Motor Head on topic kz750 ltd 1981 cam chain rattle
Hydraulic Lock, oh boy. That can cause Huge damage. Be careful there Angel.
Do your Carb Float Bowls have a overflow drain tube? That would be a Brass Tube, standing up from the bottom of the float bowl, rising up just above the gasket mating surface. It will connect into the carb drain screw circuit, and then have a hose nipple on the bottom of the bowl. Some of the USA Keihin carbs do not have overflow tubes installed do to emissions laws/ requirements. If your carbs do not have them, you can install them. Check them out and see if they have the overflow tubes. You don't want to do a Hydro Lock, it will destroy your motor. My Boss just destroyed his Snowmobile Motor over New Years, Hydro lock.
- turboking
- Thank you received: 106
03 Jan 2013 10:24 - 03 Jan 2013 10:25 #565678
by turboking
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Replied by turboking on topic kz750 ltd 1981 cam chain rattle
:blink: can you turn the engine over by hand using the ignition end crank bolt?
if it will not turn over by hand the cylinders may be full of fuel, you can remove the spark plugs and crank the engine over with the electric starter. fuel will come spewing out of the spark holes. rags over the the holes to catch the fuel and be sure the spark plug boot ends are no where near the fuel soaked rags(fire hazard). if this is what happened you will have to drain the oil as it's gassed up and will hurt bearings in the long run if not changed. you still may have a starter sprag problem from the sound of it.
just my 2 cents worth
1985 GS 1150E
1983 GS 1100E
Last edit: 03 Jan 2013 10:25 by turboking. Reason: spelling
- turboking
03 Jan 2013 10:28 #565679
by turboking
1985 GS 1150E
1983 GS 1100E
oops :huh: missed your last post.
1985 GS 1150E
1983 GS 1100E
- steelhorseangel
03 Jan 2013 11:50 #565684
by steelhorseangel
Angel
x God Bless x
hi kzr's!
happy new year ya'all!
the start noise is bad, it wasn't a hydraulic lock at all.
i still think it's the starter clutch. what i don't understand is i remove
all of my spark plugs from cleaning and the noise stopped. put the plugs back in
at the metal on metal noise is back.
1) i would like to upload another video on this the forum so that others
can help me identify the problem it please. i won't be the first nor the last to hear this
noise.
*** what video format do i use please, *.mpeg, *.avi, other?
2) has anyone ever written any installation instructions for put these starter clutch in
please? i've searched the forum and i couldn't find one.
many thanks
angel
noise.
many thanks
angel
Angel
x God Bless x
- Lorcan
- Speed Loony
- Thank you received: 59
03 Jan 2013 11:58 - 03 Jan 2013 12:00 #565686
by Lorcan
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
Replied by Lorcan on topic kz750 ltd 1981 cam chain rattle
Instructions are in the workshop manual which you can buy from your dealer and (probably) on ebay. The workshop manual, not to be confused with the tiny owner's manual, covers pretty much everything you will ever need to work on the bike.
Cranking the bike over with the plugs out will give the starter motor/clutch/battery an easier time as the motor will have no compression, so if these items are marginal they may well act normally with the plugs out.
760cc - 8.69@162mph
Last edit: 03 Jan 2013 12:00 by Lorcan.
The following user(s) said Thank You: steelhorseangel
- APE Jay
- Banned
- Thank you received: 58
03 Jan 2013 14:02 #565694
by APE Jay
Replied by APE Jay on topic kz750 ltd 1981 cam chain rattle
When the new tensioner makes the rattle go away, please be sure to come back on here and let everyone know.
- steelhorseangel
03 Jan 2013 18:01 #565748
by steelhorseangel
Angel
x God Bless x
hi motorhead!
yes my cv34 carbs do have overflow
pipes, all fitted, with clips!
no problems there. i've had a blonde
moment and turned the pingel on
more than once. hence the unused fuel.
i've now drained off the carb bowel
fuel.
i don't have any help with the starter clutch.
i can't work underneath the sump, due to neck
injury. i've contacted two brit bike shops.
one quoted a 4 hour job, the other 2 hours.
£60 brit pounds for labour and i buy my
own parts. makes my life easier!
i'm injured guys, shunted by white van
builder van!
thanks again!
regards
angel
fuel.
builder van!
thanks again!
regards
angel
Angel
x God Bless x
- steelhorseangel
03 Jan 2013 18:05 #565750
by steelhorseangel
Angel
x God Bless x
hi loran
thank you. i've an oem workshop manual, a parts
book and an original owners manual.
i did find a pdf file on kzr's info share files.
this is brilliant instruction and guidance.
very well written, many thanks all! x
regards
angel
regards
angel
Angel
x God Bless x
- steelhorseangel
03 Jan 2013 18:07 #565751
by steelhorseangel
Angel
x God Bless x
hi jay
will do!
what i will do is to record a second
video and others can compare it to
the original potato cutter start up noise!
many thanks!
angel
will do!
many thanks!
angel
Angel
x God Bless x
- gengomerpyle
- Thank you received: 17
03 Jan 2013 19:47 #565764
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Replied by gengomerpyle on topic kz750 ltd 1981 cam chain rattle
have you tested the starter it self?
1982 GPZ750R1 ELR
1971 Honda CB750K
- steelhorseangel
03 Jan 2013 21:12 #565772
by steelhorseangel
Angel
x God Bless x
hi
thank you for your question!
yes the starter motor has been tested,
good instant torque. on this forum
there is a pdf file about installing the
starter clutch. the clue is in the sound
my bike makes on startup. it sounds
like a model t ford horn........
i've got my bike booked in.
sadly i can't do this job. lasses
don't have the same strength as you guys!
we make good meals though, right!
regards and thanks!
angel
regards and thanks!
angel
Angel
x God Bless x
