- Thank you received: 1
kz750 ltd 1981 cam chain rattle
- steelhorseangel
- ad@wildlifeartist.plus.com
thanks for your message!
i don't give up easily.
my dad, RIP, taught my biking brother
and i, 'do a job right, do it once!'
the bike hasn't run for a while. i've been
working away. it started perfect in the summer.'
idle steady at 950rpms.
then it got colder, like you're standing in a
freezer colder and then the cam chain/other
rattle started, it sounds like nuts in biscuit tin!
well nearly!
the tensioner was worn. just ordered
an ape manual one from the U.S
a lot cheaper than the UK.
$97 in the UK, $57 incl. shipping!
getting very excited about a quieter engine
i don't understand how your bikes work,
in your climate, yet mine suffers in cold
weather.
the fuel is fairly new, some weeks old.
i bought a por-15 fuel additive to stop
it going off, thoughts on this additive?
is it beneficial or a waste of $... ?
many thanks kzr's!
angel
Angel
Restore, Wrench & Ride!
Brought up with Dad, brother, all riders!
Our Dad (Eric) taught us both simple mechanics
before he went to the happy hunting ground, too soon (44)
My KZ is now called Eric and he will ride and protect me!
x God Bless x
- ramtough_63
stay after it i am sure you'll have her purrin again in notime the weather where i am is crazy wet rainy 20's-70's in same day cloudy wet to warm and dry
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- havakaw
- Thank you received: 27
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- Thank you received: 2829
Attachment aSnowDayBike.JPG not found
- steelhorseangel
wishing everyone a happy xmas!.. not long to new year either! hic!..
i've been away and wanted to thank everyone with all the help with my bike!..
i've now removed the seized oem cam chain tensioner, this was one of the rattles that
sounded mechanically wrong!.. i've now replaced it with an APE KT1000 manual cam chain
tensioner and it certainly has quietened down the CCT. highly recommended!
i've now got another 'metal on metal' noise on start up?
the bike won't fire up due to this noise?
i've checked the following:-
1) starter solenoid/relay - it 'clicks'.
2) starter motor, great torque, this part has never been apart.
3) while the started was out of place. the oem manual advises
check the starter idle gear for turning freely CCW and this it does.
then i checked CW and it locks like it supposed to do.
Could it be a worn starter clutch? i can't do this myself as i feel it's too technical.
i've had someone make some videos for me, does anyone recognise the start up metal on metal sound.
it's sounds wicked?
many thanks for any advice given and wishing you all a very happy new year wrenchers and riders!..
angel
x
kz750 starter motor idle gear testing.MOV
Angel
x God Bless x
- steelhorseangel
Angel
x God Bless x
- Motor Head
- Thank you received: 391
- steelhorseangel
can someone explain how to post videos
on here please. it has been a festive time
guys!....
many thanks
angel
Angel
x God Bless x
- steelhorseangel
please see the attached videos, i've now converted them to *.mpg.
so sorry about not converting them. i've many formats on my complex system.
i don't know what this noise is. the usa engine in my bike has only done 6,800 miles.
on a 81. so very little use.
i showed the little videos to a local bike mechanic and he seems
to think that it's unused fuel that is caused a gas lock. he has asked
me to remove all spark plugs, then cover the cylinders with a sheet and start it up
to blow out any used fuel. this is give the false impression that it's a starter clutch
problem.
quote: "i need to take the engine out to do the starter clutch!"
this is not the case is't wrenchers?
many thanks for your constructive advice!
kind regards
angel
Attachment kz750adstartupnoisedec3112002_mpeg1video.mpg not found
Attachment kz750startermotoridlegeartesting_mpeg1video.mpg not found
Angel
x God Bless x
- Lorcan
- Speed Loony
- Thank you received: 59
You can get a replacement starter clutch if you need it from your Kawasaki dealer.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- KZJOE900
- Admin
steelhorseangel wrote: hi kzr's
problem.
kind regards
angel
Hi Angel, you will first need to upload the video file to a media hosting site such as YouTube. Photobucket or flicker may also allow video. Which ever you have an account on. Then edit this post and you can remove the bad links and replace them with a link to the YouTube or whatever site by pasting in the URL that you copied from that site. If you would like to embed the video in the post instead, there is a film strip icon that you will see when editing a post. Just click on that icon and paste the URL in there instead. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Motor Head
Now the second one where your turning the gear in one direction then it holds in the other, you cannot apply the same amount of pressure as will be applied under starting conditions. It does sound like the starter clutch. As others have posted you can service it with the engine installed on the 4 cylinder bikes. I would pull it out and inspect it, look close where the gear hub bolts to the Flywheel/ Rotor. There are three allen headed bolts that come loose. This could be your problem. The only special tool you might need is the Rotor Puller Bolt. Some use either the axle sahft or maybe the upper steering stem bolt, as one or the other is probably the correct thread and size. 18 x 1.5 mm I believe. All the parts should be available, and repalcing the roolers and springs would be the minimum. z1enterprises has a kit and the parts seperate for most models.
