Uh Oh Low Compression
- steell
wireman wrote: Did anybody else notice the numbers jumped between 30-50 psi by dumping a little oil in the cylinders or is it just me again? :laugh:
Ever seen a motor, even a new one, that the numbers didn't increase when you add oil?
10% leakage is the commonly accepted number on a new broken in motor, and when you add oil you reduce the leakage to zero (or near enough). Take a newly rebuilt GPz750 that's just broken in and has 180 psi compression, add oil and it will be over 200.
If you have a motor in great condition, try it yourself. Do a dry compression test then a wet test.
- wireman
- Thank you received: 299
- KZJOE900
- Admin
ThatGPzGuy wrote:
bountyhunter wrote: zero valve clearance equals crappy compression.
Got it. I understand 2 and 3 need to be adjusted but I am not getting very good results with 1 and 4. I am afraid I'll go thru all the work of adjusting the valves just to have to tear into it again to do the rings.
I would think the valves will need to be adjusted anyhow, no matter what. So you won't actually be doing any extra work for yourself other then taking the tank off and valve cover. But its worth the extra information you will gain from doing another compression test and leak down test after the adjustment.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Thank you received: 2098
The added oil helps prevent loss of compression past the pistons/rings into the crankcase.
But, the added oil generally doesn't help prevent loss of compression through a leaking valve.
- ThatGPzGuy
- Thank you received: 385
Although I've had this particular bike for the last 5 yrs and 4,000 miles I don't think it was well cared for before me. I also paid someone to adjust the valves about two thousand mile ago and I find it hard to believe they would go out of adjustment this quickly (if he did what he said he did).
I'll take the advice of those on the board and adjust the valves and see what that gets me.
Steell, what makes you think #4 has a stuck ring?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- ThatGPzGuy
It was a lot easier than I thought it would be. All of them were fine except #2 and #3 intake valves. The only one that worries me is #2 since it had no clearance and a 2.15 shim. The chart calles for a 2.00. What if that does not provide enough clearance? Time for a valve job?
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- wireman
- ThatGPzGuy
I would think not.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Presumably, a similar procedure would apply to other models.
22,000 miles seems awfully low mileage to already be at the thinnest shim size.
- wireman
No Im just saying to pull the shim out and see what you have for total clearance without the shim then subtract the clearance you need from that number,that will give you your required shim size.ThatGPzGuy wrote: I could but the smallest shim in the chart is the 2.00.I don't suppose I could run without a shim?
I would think not.
That way you know if you can shim what you have,or if the head needs to be pulled off for more work.
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
But if your valve clearances were wrong, as you said the clearances were too tight, maybe you have burned valve seats and the valves are not sealing and that's why you're losing *some* compression. But at 22k miles, no way are your valve seats burned to the point that you need a thinner shim than in the shim chart or you have zero compression. The compression in 1 and 4 is low. The zero compression in 2 and 3 is not reliable in my opinion.
However, if you had someone else adjust your valves previously, and it was *not* because you were too busy with work or something, here's what I'd do:
1) read the valve clearance checking procedure in the factory shop manual for your bike, not a Clymer or Haynes manuals, the *factory shop manual* for your year/model bike, and make 100% certain you understand how to check clearances correctly -- not 'I think I got it' degree of certainty, but "My favorite Grandma's life depends on me getting this valve clearance check right -- otherwise she'll die" I mean you are *certain* you are checking the clearances right.
2) now re-check the valve clearances.
I just really find it hard to believe you're at zero compression on #2 and #3 if as you say, you paid someone only 2000 miles ago to adjust the valves. Surely they would have told you that you were at the margin. Zero compression is catastrophic failure.
Having the valves stay open due to no valve clearance/shims too thick just 2000 miles after they were last adjusted, no. I just don't buy it.
If your valve seats are just burnt bad, I guess that's possible, but again not 2000 miles after a *correctly done* recent valve adjustment.
Unless the person who did the valve adjustment 2000 miles ago was high or something and got it wrong or was otherwise incompetent.
Also, buy a 2nd compression tester *just to be sure.* I have three different compression testers, they're not that expensive, that way if I catch myself saying 'the compression's fine, this gauge must be out of calibration' I grab another one to get a '2nd opinion.' I don't mess around with it sometimes, I take the carbs all the way off. I want a compression test. Especially if I have CV carbs, I yank 'em. I want a solid reading from the bores and the CV carbs have a butterfly valve, not a direct means to *guarantee* the throttle slide is opening for the compression test.
Something's fishy here. I just don't think a 22,000 mile KZ motor has hit the "Shim limit" in that chart. I just don't see how a valve seat can lose that much material after only 22k miles to put you limit-down out of the shims chart to the point where you need a thinner shim than is in the chart. Check your method of performing the valve clearance check. Maybe yank the carbs and re-check compression.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- ThatGPzGuy
Here is where we are: I got a 2.00 shim from my local kawsaki dealer and was able to get the proper clearance on one of the valves however the other one requires a 2.05 which I did not order. I learned this by using Wireman's adice and measureing the gap with the smaller 2.00 shim. So,once i get all the the shims collected and installed I should be good to go. However the #3 intake will bear watching (it will have the thinnest shim). My next course of action is to check and double check the compression and perhpaps do another leak-down.
NewOld, Thanks for taking the time to reply. After checking the valve clearances a few times I am sure I got a pretty good handle on it. It is actually easier than I thought it would be. And yeah, the guy I paid to adjust the valves and sync the carbs was a bit of a flake. I don't think he is in business anymore.
I'll post my compression results after it is all back together (minus the carbs).
Thanks again,
JIm
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
