- Thank you received: 385
Uh Oh Low Compression
- ThatGPzGuy
19 Dec 2012 14:45 #563690
by ThatGPzGuy
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Replied by ThatGPzGuy on topic Uh Oh Low Compression
Ok The results are in.
I ended up going to 2.00 shims on the 2 and 3 intakes. I think there may be a valve job in my future but for now I have the proper clearances.
I did a compression check while the carbs were off and got a consistent 135-140 across all four. Hurrah! I have not rode it yet but it starts easier and idles much smoother. I also took the opportunity to clean the carbs and replace the intake manifold boots and one of the airbox boots.
So far so good. However I noticed I have pressure from the right side crankcase breather. I checked the reeds (although not closely) and did not see any apparent cracking.
What would cause this?
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- KZJOE900
- Admin
19 Dec 2012 14:55 #563692
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Replied by KZJOE900 on topic Uh Oh Low Compression
Congrats! 135-140 is pretty dam good. I have no idea about what the standard / service limit compression is for your bike. But I would assume these are good numbers. Balance the carbs and it will run even smoother. Certainly doesn't sound like new rings and valve jobs are required just yet.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Kitten Tooth
- Thank you received: 10
19 Dec 2012 15:24 #563695
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic Uh Oh Low Compression
Good job man, Your compression is as awesome as mine now!! I can't even fit my smallest feeler gauge in to check the clearance on the Exhaust valve for cylinder 4. Good god.. valve adjusting would do wonders for my bike. Glad yours is running good.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
