KZ305 wont start randomly :(
- Zachs305
82 kz305b
- KZJOE900
- Admin
Zachs305 wrote: It cranks, It just wont start right now. It turns over but seems to not get any spark. Im thinking it is the ignition coils. The points are opening and have spark in between them but idk so I found a tune up kit that has new ignition points and coils. Imma try them out.
Zach, are you saying you are seeing a spark when your points open and close between the two points contact? That is called arcing and will burn the points. I think the cause of arcing is too small of a gap. You may need to adjust your points. Have you done any point adjustment lately? Mine wouldn't start after I took the base plate out in order to hammer it flat. Had been damaged by the P.O. When I replaced everything I thought I set the gaps correctly (dual points) but one was off. Bike wouldn't start. Just thought it may be worth checking. And aside from that, remember, the part of the points that contact the ignition cam wears (some kind of composite material) and means the point gap gets progressively smaller with time from wear. You may just have reached the threshold in wear were the points are arcing and the bike won't start. Just food for thought.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- chonus
- Thank you received: 8
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
- Zachs305
82 kz305b
- donthaveakawman
- Visitor
- chonus
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
- Thank you received: 2098
1. Remove spark plugs, and attach them inside the caps that connect them to the plug wires from the coil --
2. Ignition switch ON; transmission in neutral; kill switch in RUN position; clutch lever squeezed; kick stand UP --
3. Hold the bases of the plugs against the engine head --
4. Spin over the engine with electric starter or kick starter --
5. Look for sparks at tips of the plugs.
Wanting to see fat blue sparks -- not weak orange sparks.
Fat blue spark is evidence of a serviceable ignition system, but doesn't guarantee that the spark plug will fire under compression after it's re-installed.
The better practice is to fit brand new spark plugs of the exact type recommended in the factory service manual.
- Zachs305
and no no luck quite yet, Ive been too busy to be working on it because of finals but I hoe to start working on it again next week
82 kz305b
What is measured voltage being received at the coil?
- Zachs305
82 kz305b
