KZ305 wont start randomly :(
- Zachs305
Zach
82 kz305b
- donthaveakawman
- Visitor
- Thank you received: 2829
- Zachs305
650ed wrote: Did you ever replace the regulator that the previous owner (idiot) removed? Ed
It turned out that they didn't bypass it, the wires were just dead and I got that fixed luckily.
82 kz305b
- Thank you received: 2098
Zachs305 wrote: ...bike wouldnt start. I bought this bike just a few weeks ago and have never had any problems starting it... got it started for a sec and it wouldnt accept any throttle...have taken the carb apart to see if it was dirty but havnt noticed anything. Tomorrow I am going to go into it and try and clean all the jets out....
Assure the rubber plug is properly fitted.
- Zachs305
Patton: Thank you I am going to have to be sure and check those passage ways, Im not sure that I checked them correctly
82 kz305b
Click > www.armbell.com/forum/viewtopic.php?t=11...+manual&mforum=kz400
- Zachs305
82 kz305b
- donthaveakawman
- Visitor
With a good fully charged battery properly installed and connected, could remove both spark plugs from their holes in the engine head, leave the plug wires from the ignition coils connected to the spark plugs, hold the bases of the spark plugs grounded against the engine head, and then spin over the engine as if attempting to start it running, and while spinning over the engine, observe the tips of the spark plugs to determine spark quality -- look for strong blue spark, and not weak orange spark.Zachs305 wrote: Does anyone think it could be my ignition coils? Does anyone know how to check?
If there's no spark from either plug, would try this test again, using brand new spark plugs of the type specified in the factory service manual.
May ohm-test the primary winding on each ignition coil.
The resistance, measured in ohms, using an ohmmeter, should fall within factory specs.
If the primary wiring inside the coil is shorted, the ohm test may reveal a broken circuit.
But passing the ohm test doesn't guarantee that the coil isn't shorting internally after it heats up.
Kawasaki dealer service technicians may have available an "electrotester" which measures the spark producing capability of an ignition coil.
There are many reasons other than a faulty coil than can cause spark failure at the tips of the spark plugs.
- donthaveakawman
- Visitor
1-take off the distributor cap
2-mark the spark plug wires
3-take off the distributor rotor
4-turn engine to see if points are opening and closing properly
5-if the points are opening and closing properly follow a, if they are malfunctioning follow b
6a-check the wiring and electrical 6b-replace points and gap to spec
7a-try again 7b-try again
8a-when started drink a beer and wait an hour before taking it on the road
8b-when started drink a cold beer and wait 1 hour before going on the open road. a job weld done.
- donthaveakawman
- Visitor
