- Thank you received: 10
Valve adjustments
- Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Thank you received: 2098
Minimum = 100psi (but may actually run pretty good with less)
Best if difference between cylinders is less than 14psi.
#4 exhaust valve needs a thinner shim.
- Kitten Tooth
Once again,
Thanks guys.
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
3 parts series!! got 2 more videos to upload of removing the valve cover and the results i got at the end.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- mark1122
- Keep twisting it
- Thank you received: 109
u will see a notch in the rim of the bucket. a special tool fits into the notch. then u compress the bucket a wee bit with the tool and then pick the shim out from on top of the bucket.
look up the procedure in your manual and u will see what i mean.
There is no need to take the cams out, unless someone has changed the buckets to the shim under bucket style.
They would only do this if they wanted to add high lift cams.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
- Thank you received: 299
Passing the rings is not normal! :laugh:Kitten Tooth wrote: Also did a leak down test and all i heard was hissing from the crank case (passing the rings like normal)
- Kitten Tooth
Heres the 2nd video
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- wireman
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
And theres the 3rd video with the notebook and the specs.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- baldy110
- Thank you received: 512
