- Thank you received: 10
Valve adjustments
- Kitten Tooth
Thanks for everything guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Del_Herring
- Thank you received: 29
Then you can figure out how much bigger of a shim you need. You can measure the old ones, but they really shouldn't wear down, they're typically made of a hard material, so other stuff is what wears down. You should be able to grab feeler gauges for like $5 from an autoparts store. But I'm guessing from your other adventures you already have some somewhere.
1983 KZ750-N2 Spectre
- Kitten Tooth
Thanks guys,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- wireman
- Thank you received: 299
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- wireman
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
Cylinder 1 Valve lash
INTAKE- .003 (no .004 gauge on hand)
EXHAUST- .0025 (.003 doesnt fit)
Cylinder 2 Valve lash
INTAKE- .002 (.0025 doesn't fit)
EXHAUST- .005 (.006 doesn't fit)
Cylinder 3 Valve lash
INTAKE- .0025 (.003 doesn't fit)
Cylinder 4 Valve lash
INTAKE- .005 (.006 doesnt fit)
EXHAUST- Not even my smallest gauge would fit.
None of my gauges would fit Exhaust on cylinder 4. I have done nothing with adjusting the valves on this bike and i do not know why the clearance is so tight. If anything was wrong you would think the clearance would be loose (due to carbon holding a valve open or the valve being bent. I also noticed a wear mark on the heel of that cam lobe (the side that is pointing towards the valve when the valve is closed) not a groove or scratch, just a line where the metal is darker than the rest of the lobe. Also, the nose of the intake cam lobe on cylinder 2 looks to be kinda blue like it got hot. I have seen this on other engines before so im not stressing that really.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- bountyhunter
- Thank you received: 337
In most cases they get a shade tighter over time as the valve seats deeper into the head. That's why you have to check them frequently, a tight valve will burn out a valve seat as well as cause poor running.Kitten Tooth wrote: i do not know why the clearance is so tight. If anything was wrong you would think the clearance would be loose (due to carbon holding a valve open or the valve being bent.
If you are fouling a plug with oil that means a valve seal is toast. Compression of 130 isn't great (I thought the fours ran higher). Sounds like the engine could use a valve job.
FYI: on these kind:
You should reach in and see if you can rotate the lifter without binding. If so, you likely have a little clearance which means it's less than the feeler gauge size but more than 0. That lets you calculate the shim you need to fix it.
- Kitten Tooth
With the clearances i listed, how do i know what shim sizes to get? If the valves tighten up, how come they chatter so much? I do have the new valve stem seals but i dont have the money for the new headgaskets as im sure i gotta remove the heads to replace it...
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
