GPZ motor
- stain
Re: GPZ motor
06 Nov 2012 14:14
I have the poor mans version of those on my GS1085---stock carbs off a 90 GSXR1100, BST36 I believe
- stain
Re: GPZ motor
22 Nov 2012 20:05
A little update. I thought I had an 81 engine and an 82 engine. After measuring the cams in both motors it seems I have 2 81 engines. The 82's had the same cam intake and exhaust according to my manual. Anyone run 2 intake cams in an 81 GPZ engine? Is it that much of an upgrade? Anyone have any upgraded cams or ideas? I don't want this project to get out of hand money wise. Who is the best to send the head to for a street valve/port job?
Any insight/tips would be appreciated. Thanks.
- woodman
Re: GPZ motor
22 Nov 2012 20:42
zukdave.....Just my own personal opnion based on having both sets of carbs, keep the 29s if its a street bike, trade if its a race bike. This is on an 1105 sleeved 900 with headwork, cams, & Kerker. Maybe someone can get the 33s to consistenly idle right but Im not one of them
- mark1122
- Keep twisting it
Re: GPZ motor
22 Nov 2012 21:12 - 22 Nov 2012 21:12
i have used and loved the vm33's on my 1135. for head work email or pm Larry Cavanough racing at
[email protected]
[email protected]
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 22 Nov 2012 21:12 by mark1122.
- LarryC
Re: GPZ motor
22 Nov 2012 21:43
There's good and bad racks of carburetors out there in all sizes. With enough tuning effort, you can make anything pull hard in the upper rpm range. It's dialing in the bottom end for good street behavior that separates the men from the boys....
FUEL LEVEL is THE FIRST THING TO GET RIGHT BEFORE YOU JET. That, of course is preceded by knowing you have a healthy engine to start with.
Larry C.
- APE Jay
Re: GPZ motor
23 Nov 2012 18:58
The GPZ had 2 bolt cam sprockets. Instead of making new billets for that engine, the cam grinders all used the earlier 3 bolt cams and you had to use an adaptor cam sprocket made by one of the "leading performance parts manufacturers"
So if you have 2 bolt cams in your motor, unless the lobes have been welded, they would be stock.
- 79MKII
- Love Them Kaws!
Re: GPZ motor
04 Dec 2012 22:00
I've heard some negative things about the 33's but I've used them since 1988 when I bought my MKII. At the time, it had a 1075 kit and mild cams. It now has a 1260 kit and .425 cams....the 33's have run perfectly for me all these years. If you already have them you might as well try them out and make up your mind.
The Kaw List:
- zukdave
Re: GPZ motor
04 Dec 2012 23:49
Woodman I was thinking the 33's for after I
build the motor.
Game plan is the 810 kit I've got and see
about having Larry C. doing the head work.
build the motor.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
