GPZ motor
- stain
This is my first Kawi engine as I have been working mainly on Suzuki's. Can anyone tell me if this was an aftermarket kit of some sort or maybe just an overbore?
Thanks
- wireman
- Thank you received: 299
Ive got a block and set of those pistons someplace I bought from kano here on the site a few years ago.
- stain
- wireman
- stain
- stain
[attachment:2]C:\fakepath\1982 GPZ camshafts 002.jpg[/attachment]
[attachment:1]C:\fakepath\1982 GPZ camshafts 001.jpg[/attachment]
I am having troublr getting my pictures to load
After some research and measuring it seems as these might be cams from a KZ1000. The exhaust cam lobes are different from the intake and my manual says the B2 cams were the same. Also the B2 cam gears were marked as such and these say Z1000 as it would on a KZ1000. Is my thinking corrrect? Why would someone do this? Is this supposed to be a performance upgrade? Any suggestions on what to put back into it?
- Thank you received: 2098
Attachment picpostnewsite912x671.jpg not found
- stain
- wireman
- stain
- zukdave
- Thank you received: 229
stain wrote: seems the 33mm smoothbores were a little overkill for stock head and cams??
Trade for my VM29's ?
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- baldy110
- Thank you received: 512
stain wrote: It seems the 33mm smoothbores were a little overkill for stock head and cams??
I am running RS36's on my 1135cc kitted GPz1100 with mild porting, stock cams and a 4 to 1 Kerker. I LOVE these carbs, I have tons of low end torque, amazing midrange and lots of top end. I would use the 33's.
