GPZ motor
30 Oct 2012 19:27 #556438 by stain
GPZ motor was created by stain
I just purchased an 82 GPZ1100 parts bike for a project I have been sitting on for a few years. I purchased the bike mainly for the 33mm smoothbores that came on the bike. The thought in the back of my head was with the bigger carbs maybe there was some goodies inside. I removed the top end to find a 75mm bore with Weisco pistons. The cams don't have any markings on them but the cam gears read Z1000, they are NOT slotted.
This is my first Kawi engine as I have been working mainly on Suzuki's. Can anyone tell me if this was an aftermarket kit of some sort or maybe just an overbore?
Thanks
  • wireman
31 Oct 2012 00:02 #556483 by wireman
Replied by wireman on topic GPZ motor
Sounds like an 1170 kit,which would be the biggest you can run in the stock 1100 sleeves.
Ive got a block and set of those pistons someplace I bought from kano here on the site a few years ago. B)
31 Oct 2012 07:25 #556505 by stain
Replied by stain on topic GPZ motor
I'm guessing the cams are stock.........
  • wireman
31 Oct 2012 12:40 #556539 by wireman
Have you got a picture of the cams? B)
31 Oct 2012 20:37 #556612 by stain
I will take some after I charge my camera battery
01 Nov 2012 19:04 - 02 Nov 2012 00:03 #556705 by stain
[attachment:3]C:\fakepath\1982 GPZ camshafts 003.jpg[/attachment]
[attachment:2]C:\fakepath\1982 GPZ camshafts 002.jpg[/attachment]
[attachment:1]C:\fakepath\1982 GPZ camshafts 001.jpg[/attachment]
I am having troublr getting my pictures to load
After some research and measuring it seems as these might be cams from a KZ1000. The exhaust cam lobes are different from the intake and my manual says the B2 cams were the same. Also the B2 cam gears were marked as such and these say Z1000 as it would on a KZ1000. Is my thinking corrrect? Why would someone do this? Is this supposed to be a performance upgrade? Any suggestions on what to put back into it?
Last edit: 02 Nov 2012 00:03 by stain.
01 Nov 2012 20:23 #556715 by Patton
Replied by Patton on topic GPZ motor
Attachment picpostnewsite912x671.jpg not found
Good Fortune! :)
02 Nov 2012 22:13 #556864 by stain
Could I have an KZ1100 motor painted black in a GPZ frame?
  • wireman
02 Nov 2012 22:18 #556866 by wireman
Yes any 1000/1100 j series motor could be made to look like a gpz motor if you didnt check numbers on front of cylinder or serial number on cases B)
04 Nov 2012 09:24 #556992 by stain
Well if it is a J motor I still think I am OK. I want the 1170 kit in it and the cylinder head. I will use some APE cams or the stockers out of the other GPZ motor I have. It seems the 33mm smoothbores were a little overkill for stock head and cams??
04 Nov 2012 23:52 #557072 by zukdave
Replied by zukdave on topic GPZ motor
stain wrote: seems the 33mm smoothbores were a little overkill for stock head and cams??
Trade for my VM29's ?
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
04 Nov 2012 23:58 - 04 Nov 2012 23:59 #557074 by baldy110
Replied by baldy110 on topic GPZ motor
stain wrote: It seems the 33mm smoothbores were a little overkill for stock head and cams??
I am running RS36's on my 1135cc kitted GPz1100 with mild porting, stock cams and a 4 to 1 Kerker. I LOVE these carbs, I have tons of low end torque, amazing midrange and lots of top end. I would use the 33's.
Last edit: 04 Nov 2012 23:59 by baldy110.
