spark plug threads
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
Re: spark plug threads
21 Oct 2012 00:28 - 21 Oct 2012 07:36
#554930
here is a link on how to make an aftermarket ignition for your kz, i would not recommend doing this if you are not good with wiring.
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
Last edit: 21 Oct 2012 07:36 by Patton.
  • donthaveakawman
21 Oct 2012 18:39 - 21 Oct 2012 18:43
#555016
:blink:
BlackZ1R wrote: Hey don't worry, we aren't gonna badger you like Vince would. :evil: Looks like you used the PermaPlug kit.
Never used that one, but it's pretty much the same as the PermaCoil and Heli-Coil kits. They all work the same. Both the HeliCoil and PermCoil taps have a longer pilot than that one.
I've had great luck keeping the chips out of the engine using thread cutting wax. Once you pack the flutes with this stuff, nearly all the chips are created past the pilot section, so the wax holds them up higher on the tap. Good stuff.
toolmonger.com/2009/08/28/castrol-stick-wax/
if you talk to vince again can you tell him i want z rated tires because i mentioned his name on here, also i am not unhappy with the size 14 front sprocket. :blink:
Last edit: 21 Oct 2012 18:43 by donthaveakawman.
  • donthaveakawman
21 Oct 2012 18:42
#555018
donthaveakawman wrote: here is a link on how to make an aftermarket ignition for your kz, i would not recommend doing this if you are not good with wiring.
i am going to print this so i don't lose it if the dude deletes the link.
  • donthaveakawman
26 Jan 2013 19:36
#569403
umm the helicoil came out now I have it back in part of the way with threadlock and it won't move.
  • DoubleDub
  • DoubleDub's Avatar
26 Jan 2013 20:44
#569412
Probably because your rods stretched.
  • wireman
  • wireman's Avatar
26 Jan 2013 22:50
#569426
:laugh: :laugh: :laugh: :laugh: :laugh:
  • donthaveakawman
26 Jan 2013 23:30
#569429
I'll stretch your rods.
  • wireman
  • wireman's Avatar
26 Jan 2013 23:35
#569433
Im right down the road in carmel california for 2 weeks,pack a lunch! :woohoo:
  • donthaveakawman
26 Jan 2013 23:46
#569442
uh oh.
  • wireman
  • wireman's Avatar
26 Jan 2013 23:47
#569443
Exactly! :laugh:
  • donthaveakawman
27 Jan 2013 00:06
#569445
yeah, I don't think there is any corn fields around here anywhere.
  • donthaveakawman
27 Jan 2013 00:19
#569446
wireman wrote: Exactly! :laugh:
you better take peavylotus up on that head and carbs while you are near here.
