spark plug threads
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
Re: spark plug threads
15 Oct 2012 02:26
#553914
BlackZ1R wrote:
daveo wrote: Do you recommend using anti-sieze lubricant? My plugs are a pain to remove sometimes.
YES
Don, you sure know how to strip 'em don't you? :P what sleeve did you use?
the depth is .75 the threads are 14mm
  • donthaveakawman
15 Oct 2012 02:28
#553915
donthaveakawman wrote:
Attachment hanginbyathread.jpg not found
hanging by a thread
Attachment screwingit.jpg not found
screwing the tap
Attachment donedeal.jpg not found
done deal
don't try this at home kids!
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
15 Oct 2012 02:29
#553916
YES
Yes. What type do you use? Heli coil, perma thread, Time Sert?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • donthaveakawman
15 Oct 2012 02:31
#553917
it hasn't rained in about three months, i really think there is something syfy channel going on with the weather, this is Washington.
  • donthaveakawman
15 Oct 2012 02:57
#553919
i know this is a little un-related, but does anyone else have the problem where their toe catches under the footpeg?
Attachment oops.jpg not found
:woohoo:
15 Oct 2012 09:41
#553941
yep....All metals have a property called nobility. It is a measure of a metal's resistance to corrosion when in contact with another metal. A greater relative difference in nobility between the two metals in contact indicates a greater corrosion potential. Alum is a 1 while steel is a 4....so a corrosion potential is high between cyclinder and spark plug.....when you use an antisieze...it conditions the two metals and keeps them apart while creating a lubed surface that makes removal and install easy without galling. Always install plug by hand not with wrench untill it bottoms out...I would also use a torque wrench to set final torque per manual specs.
+1 !
  • martin_csr
  • martin_csr's Avatar
15 Oct 2012 12:46 - 23 Jan 2013 11:09
#553969
Did any shavings drop down into the hole?
Last edit: 23 Jan 2013 11:09 by martin_csr.
  • donthaveakawman
15 Oct 2012 14:40
#553989
that link is useful but i am not a big fan of pdf-files.
  • donthaveakawman
15 Oct 2012 14:47
#553990
i bought the retap kit i used the smallest one and it went in too far, i couldnt use the thing that i should hit with a hammer, i got microscopic shavings in the cylinder but it is aluminum pistons vs steel sleeves and aluminum shavings.
Attachment watchmeexplode.jpg not found
  • BlackZ1R
  • BlackZ1R's Avatar
15 Oct 2012 18:15
#554037
Hey don't worry, we aren't gonna badger you like Vince would. :evil: Looks like you used the PermaPlug kit.
Never used that one, but it's pretty much the same as the PermaCoil and Heli-Coil kits. They all work the same. Both the HeliCoil and PermCoil taps have a longer pilot than that one.
I've had great luck keeping the chips out of the engine using thread cutting wax. Once you pack the flutes with this stuff, nearly all the chips are created past the pilot section, so the wax holds them up higher on the tap. Good stuff.
toolmonger.com/2009/08/28/castrol-stick-wax/
Kawasaki
  • martin_csr
15 Oct 2012 18:40 - 23 Jan 2013 11:10
#554044
never mind then good luck
Last edit: 23 Jan 2013 11:10 by martin_csr.
  • donthaveakawman
15 Oct 2012 22:10
#554083
also there is a lot missing from that link. a good place to check is your local library website in the reference databases. although it is similar there is really no text missing.
