- Thank you received: 20
1982 GPz750 New Owner... many questions
- DesertKZ
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
- gengomerpyle
- Thank you received: 17
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- Thank you received: 2098
- david-b
- I am THAT guy
- Thank you received: 3
Last question I think for now... according the pic above, it looks like there will be no vac lines going to the carbs at all then, correct? 2 and 3 are already capped off, and then since I'm removing the tee that goes to 1 and 4, those will be capped too. So, no vacuum at all to them? Thanks
I've been looking for a new petcock (figure just replace instead of trying to rebuild this one) but not having any luck. Any ideas on where to get one?
/Dave
2013 Chevy Sonic LT 1.4L Turbo
1982 Kawasaki KZ750-H3 LTD
1975 Monte Carlo 400sbc
david-b wrote: ...according the pic above, it looks like there will be no vac lines going to the carbs at all then, correct? 2 and 3 are already capped off, and then since I'm removing the tee that goes to 1 and 4, those will be capped too. So, no vacuum at all to them? Thanks
Probably a matter of semantics, but vacuum is produced by and comes from the carb.
There is no vacuum furnished to the carb.
Where a vacuum operated petcock is the only component requiring some vacuum, all the carbs' vacuum nipples should be capped/plugged, with the sole exception of one single vacuum nipple being used to supply vacuum from the carb through a hose to the petcock.
Most 4-carb designs on our Kawasakis include a vacuum nipple on each of the four carb holders.
However, some of then include an additional fifth vacuum nipple (sometimes mistakenly identified as a vent nipple), which additional fifth vacuum nipple is dedicated to the vacuum petcock.
If the petcock is a manual petcock -- instead of a vacuum petcock -- any such additional fifth vacuum nipple should also be capped/plugged.
- Del_Herring
- Thank you received: 29
I'd definitely consider replacing that petcock though. Even if you just get an aftermarket manual one, should be fine. I'd just be worried that as soon as you have a float problem (which it seems like everyone does eventualy), you'll walk outside and find gas everywhere with the one on there, since it never shuts off. Looks like a hackjob that was done by the previous owner to get it to flow fuel instead of rebuilding it properly.
1983 KZ750-N2 Spectre
- Del_Herring
- david-b
- I am THAT guy
I don't know what the PO did honestly. Who know what was going on in his mind. I ask him and he doesn't have a clue
So I've seen on some other posts that when people have a petcock ON all the time, they install an inline on/off valve. Is that better or should I find a full vacuum petcock?
Lastly (for now), assuming I get a working petcock, is it better to run vac to it from 1 carb, or tee of multiple to the petcock? I can't see that making a huge difference but 2 sources of vac are usually better than 1.
/Dave
Vacuum from one carb is amply sufficient.david-b wrote: ...assuming I get a working petcock, is it better to run vac to it from 1 carb, or tee of multiple to the petcock?....
More lines provide more leak opportunities.
I prefer the simplicity of a manual petcock, and remembering to turn it off when parked.
It also allows turning off shortly before ride's end to lessen fuel remaining in the float bowl.
- david-b
- I am THAT guy
Patton wrote: Vacuum from one carb is amply sufficient.
Make sense and sounds good. I may try to pick up a manual petcock this evening along with fuel line and get that altogether.
One more question for now. Any good sites out there on how to really clean up the carbs? I've pulled them apart and reassembled them once already but got the rebuild kits and want them spotless inside.
/Dave
- JR
- Thank you received: 448
"One more question for now. Any good sites out there on how to really clean up the carbs? I've pulled them apart and reassembled them once already but got the rebuild kits and want them spotless inside."
Good site ? - right here !
On the top right of the page click on FILEBASE
Click on NOT MODEL SPECIFIC
Go down to the bottom and select pages 7 and 8
Lots of great info
- david-b
- I am THAT guy
/Dave
