- Thank you received: 299
Changed sprockets and now there is no clutch??
- wireman
- elfmagic17
- Thank you received: 24
Kenny Hicks
74 Honda CB550
- Flyndrive
- Thank you received: 4
Attachment image.jpg not found
1980 KZ 550A1
1985 GPZ 900R
- Motor Head
- Thank you received: 391
home.comcast.net/~loudgpz/GPZweb/Mnls/Kz...ase99924_1018_06.pdf
- wireman
Thats one of the 3 adjustments on the clutch cableFlyndrive wrote: Here the pic from the manual. Change the angle of the lever and there should be a spring.
- 4TheKZ1000
- Visitor
ajp529 wrote: Yes I did happen to pull it out.
OK....he pulled the clutch fricken rod from the engine ?????
Arent we KZ guys told from birth not to do this ????
what happens when you pull the rod out....the ball bearing does what ????
so what is with adjustment of the cable stuff??? :dry: :dry: :dry: :dry: :dry:
- wireman
Swapping ends on the pushrod keeps it from wearing in same spot all the time.
There are 3 differant clutch adjustments on the cable,that little cover in the center of sprocket cover comes off so you can adjust that actuator first,then the adjustment at the lever and finally the center adjustment on cable gets done.
You adjust the actuator differant directions on differant size bikes so check your manual to see which way it goes
- bluezbike
- Thank you received: 104
79 KZ 1000 LTD
- wireman
- sflaz1
Bought my 1973 Z1 in late 1978. Turbo charged 1982.
- loudhvx
- Thank you received: 1616
I suspect the cable has come out of the sleeve at either the lever end or the actuator end. Or the cable came out of the holder at the actuator.
Also, if he adjusted the actuator according to the manual, the directions may be wrong for the ball-pocket type actuator.
In my signature, there is a diagram for the ball-pocket type with more detailed instructions on how to adjust it.
home.comcast.net/~loudgpz/GPZweb/ClutchReleaseMech.GIF
The ball is larger than the push rod, so cannot come out through push rod channel.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- ajp529
Thanks guys youre awesome! It was the adjustment of the ball and ramp part of the clutch. Thanks!
