- Thank you received: 1
Changed sprockets and now there is no clutch??
- ajp529
After changing my sprockets, chain, and rear tire my clutch has no tension. I have taken the cover off and made sure it is all aligned correctly when I put it back in but no matter what I do there is still no tension-the clutch is just loose. I thought that I might have dropped a part or something, but looking at the schematics online it doesn't appear that I have... help?
Here is the push rod
Attachment IMG_20121003_155856.jpg not found
Here is the clutch cover
Attachment IMG_20121003_155929.jpg not found
Am I missing something?
Also how much tension do I want in the chain?
Thanks!
- 4TheKZ1000
- Visitor
- ajp529
- 4TheKZ1000
- Visitor
- ajp529
- 4TheKZ1000
- Visitor
- ajp529
It is a KZ550A.
I guess I do need to change the oil as well, so why not get messy?
- 4TheKZ1000
- Visitor
- 4TheKZ1000
- Visitor
- trianglelaguna
- Thank you received: 235
ajp529 wrote: Hi,
Thanks!
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- ajp529
If it was the bearing wouldnt the bearing have fallen down into where the push rod runs and be blocking it or causing it to engage earlier? Right now there is no tension at all in the clutch cable...
- Flyndrive
- Thank you received: 4
1980 KZ 550A1
1985 GPZ 900R
