- Thank you received: 797
Top Cam Idler
thanks for taking the time to give us all the info on the bearings sizes and sources,and how to repair the idlers if we have the equipment(i do ).
to me what fails first and how the fail doesn't matter :whistle: .
fact of business is THEY DO FAIL,
and you have led some of us(me for one)outta the dark and into the light.
i got it now and it is all thanks to you.
you have just (buy the way of sharing knowledge) moved one of my z1r's a large step closer to completion.
- Garn
- Thank you received: 13
LarryC, please don't make me lose confidence in your good work.LarryC wrote:
Really....were you in my shop, at my work bench for the last half a dozen motors I rebuilt?
This is my "hobby" shop last week.
Kind regardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- built408
1978 KZ1000 A2A with MKII body you know you like it
- sc/ant864
- Thank you received: 2
531blackbanshee wrote: zed1015,
kzrider.com/forum/11-projects/543276-77-...543286]'77KZ900-1000 streetstrip project
'77KZ900/1000
'89BMW E30 325i sedan
'88Mustang GT
'77Datsun PL620 KingCab
George Carlin- "I often think how different the world would be if Hitler had not been turned down when he applied to art school."
- LarryC
Kind regardZ.
I don't really care what you do or don't have confidence in. If you want to waste your time fk'ng around trying to make chicken soup out of chicken shit....by all means.. carry on, you're doing a fine job :kiss: I've got better things to do.
Here's what I just rebuilt. Guess what...new parts only :lol: 4 chains and lots of sprockets inside those. Just think of the fun you could have with all those sprockets :lol:
Attachment 20120911_113240.jpg not found
Attachment 20120911_113108.jpg not found
Larry C.
- wireman
- Thank you received: 299
Attachment plummen_2012-10-06.jpg not found
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
- sc/ant864
zed1015 wrote: Those idler sprockets are all the same whether kz1000 or 650.
When the rubber goes have it replaced with alloy.
As long as the teeth are ok and you keep a check on the needle bearing which is replaceable they will virtually last forever.
This is the size of bearing they need. simplybearings.co.uk/shop/p92295/BA78ZOH...ch/product_info.html
And here's a pic of the modified idlers.
'77KZ900/1000
'88Mustang GT
- sc/ant864
'77KZ900/1000
'88Mustang GT
- zed1015
- Thank you received: 1556
sc/ant864 wrote: Looking at the technical data on these bearings they show Dynamic-4460 Kn and Static-5130 Kn now I take the Kn is for Kilonewtons then upon conversion that equals to over a million pounds of force just on the dynamic. Is there a decimal point missing or what? That seems a bit overkill and just not possible for such a small bearing. Something like this is what I would be able to get.
Depending on which year engine you pull the idlers from these bearings are exactly the same as fitted to the later mk2/st etc.
The earlier years have an increase roller count but are exactly the same bore,width and dia.
When searching for these replacements i could not find any available with the higher count and concluded that they were probably specials exclusive to kawasaki as are many of the other engine bearings.
Looks like they maybe switched to an after market bearing supplier for economical reasons.
Either way they seem to be up to the job for which they are used for and i have not had any fail in all the years i have used them.
- 4TheKZ1000
- Visitor
Larry made this comment about a picture with three KZ motors on a bench being worked on.....hey Larry....you calling KZ motors "chicken shit" It sure sounds and looks that way ??????? ( see above )
- sc/ant864
Many thanks zed, I'll post pics of mine once the mod has been done, very excited about not having to shell out $400+ for new idlers! Cheers!
'77KZ900/1000
'88Mustang GT
- 4TheKZ1000
- Visitor
