Cam chain tensioner
- Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- wireman
- Thank you received: 299
- Thank you received: 2098
Model (31):
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D3 (Z1R) (1980)
KZ1000-E1 (Shaft) (1979)
KZ1000-E2 (Shaft) (1980)
KZ1000-G1 (Classic) (1980)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
KZ750-H4 (LTD) (1983)
The FSM for any of these models should provide instructions about the tension adjuster.
Perhaps there's a freely down-loadable manual around here somewhere.
- Thank you received: 2829
Patton wrote: According to kawasaki.com the same cam-chain tensioner was used on these 31 models.
Model (31):
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-F1 (1980)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
I saw this same info, but this is one area where the Kawasaki.com data has errors. The tensioners definitely are not the same across those models. I would suggest supplying a picture of the tensioner in question; maybe that will help identify which flavor it is. Ed
- turboguzzi
- Thank you received: 72
wireman wrote: You should be able to convert yours to manual with a little bit of work
indeed
- Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- Thank you received: 1656
My search shows the Cam Chain Tensioner Part No. 12049-1015 being shared on the following 26 models:
Model (26):
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ700-A1 (1984)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-F1 (LTD Shaft) (1983)
KZ750-L3 (1983)
KZ750-N1 (Spectre) (1982)
KZ750-N2 (Spectre) (1983)
KZ750-R1 (GPz) (1982)
ZN700-A1 (LTD Shaft) (1984)
ZN700-A2 (LTD Shaft) (1985)
ZR750-C1 (Zephyr 750) (1991)
ZR750-C2 (Zephyr 750) (1992)
ZR750-C3 (Zephyr 750) (1993)
ZX750-A1 (GPz 750) (1983)
ZX750-A2 (GPz 750) (1984)
ZX750-A3 (GPz 750) (1985)
ZX750-E1 (GPz 750 Turbo) (1984)
ZX750-E2 (GPz 750 Turbo) (1985)
Editing note from Patton -- Having unintentionally "edited" martin's post, this version is recalled from memory.
This place sells manual tensioners.Calico wrote: Right, changing to manual is the easiest way. In fact, there is a way to convert one from the original. I'm just not certain if I can take the slack out with a cross wedge. I'll take a picture asap and post soon. Than you to everyone!
Clem's Garage - Krieger cam chain tenisoners ... klx678 over at the kawasakimotorcycle.org site .
martin_csr wrote: I think Patton made a boo-boo. ......
He may have done the same as I. If you look at part #99996-1021 TENSIONER KIT Kawasaki.com shows it is used for all the models Patton listed. However, many of the individual parts in the kit don't fit some of the models listed because their tensioners are different. Very confusing. Ed
Thanks, martin!martin_csr wrote: I think Patton made a boo-boo....
I referenced Tensioner Kit 99996-1021 instead of Cam Chain Tensioner 12049-1015. :huh:
I think I made a boo-boo too by not looking at the Kaw diagram carefully enough... hee.
- Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
