Cam chain tensioner
  • Calico
  • Calico's Avatar Topic Author
Cam chain tensioner
28 Sep 2012 12:49
#551364
So! Here I am again. I was considering changing to a manual cam chain tensioner when someone told me that he thinks mine can be adjusted. I was under the impression that mine could not be. Does anyone know differently for an 82' 750ltd? Thank you.
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
The topic has been locked.
  • wireman
  • wireman's Avatar
Re: Cam chain tensioner
28 Sep 2012 14:06
#551391
You should be able to convert yours to manual with a little bit of work B)
28 Sep 2012 16:01
#551408
According to kawasaki.com the same cam-chain tensioner was used on these 31 models.
Model (31):
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D3 (Z1R) (1980)
KZ1000-E1 (Shaft) (1979)
KZ1000-E2 (Shaft) (1980)
KZ1000-G1 (Classic) (1980)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
KZ750-H4 (LTD) (1983)
The FSM for any of these models should provide instructions about the tension adjuster.
Perhaps there's a freely down-loadable manual around here somewhere.
Good Fortune! :)
28 Sep 2012 16:31 - 28 Sep 2012 16:32
#551415
Patton wrote: According to kawasaki.com the same cam-chain tensioner was used on these 31 models.
Model (31):
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-F1 (1980)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
Good Fortune! :)
I saw this same info, but this is one area where the Kawasaki.com data has errors. The tensioners definitely are not the same across those models. I would suggest supplying a picture of the tensioner in question; maybe that will help identify which flavor it is. Ed
Last edit: 28 Sep 2012 16:32 by 650ed.
  • turboguzzi
  • turboguzzi's Avatar
28 Sep 2012 16:39
#551417
wireman wrote: You should be able to convert yours to manual with a little bit of work B)
indeed :) :)
  • Calico
28 Sep 2012 16:44
#551419
Right, changing to manual is the easiest way. In fact, there is a way to convert one from the original. I'm just not certain if I can take the slack out with a cross wedge. I'll take a picture asap and post soon. Than you to everyone!
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
  • martin_csr
  • martin_csr's Avatar
28 Sep 2012 17:13 - 28 Sep 2012 18:10
#551426
I think Patton made a boo-boo.
My search shows the Cam Chain Tensioner Part No. 12049-1015 being shared on the following 26 models:
Model (26):
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ700-A1 (1984)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-F1 (LTD Shaft) (1983)
KZ750-L3 (1983)
KZ750-N1 (Spectre) (1982)
KZ750-N2 (Spectre) (1983)
KZ750-R1 (GPz) (1982)
ZN700-A1 (LTD Shaft) (1984)
ZN700-A2 (LTD Shaft) (1985)
ZR750-C1 (Zephyr 750) (1991)
ZR750-C2 (Zephyr 750) (1992)
ZR750-C3 (Zephyr 750) (1993)
ZX750-A1 (GPz 750) (1983)
ZX750-A2 (GPz 750) (1984)
ZX750-A3 (GPz 750) (1985)
ZX750-E1 (GPz 750 Turbo) (1984)
ZX750-E2 (GPz 750 Turbo) (1985)
Editing note from Patton -- Having unintentionally "edited" martin's post, this version is recalled from memory.
Last edit: 28 Sep 2012 18:10 by Patton.
  • martin_csr
28 Sep 2012 17:21 - 28 Sep 2012 17:21
#551430
Calico wrote: Right, changing to manual is the easiest way. In fact, there is a way to convert one from the original. I'm just not certain if I can take the slack out with a cross wedge. I'll take a picture asap and post soon. Than you to everyone!
This place sells manual tensioners.
Clem's Garage - Krieger cam chain tenisoners ... klx678 over at the kawasakimotorcycle.org site .
Last edit: 28 Sep 2012 17:21 by martin_csr.
28 Sep 2012 17:42
#551435
martin_csr wrote: I think Patton made a boo-boo. ......
He may have done the same as I. If you look at part #99996-1021 TENSIONER KIT Kawasaki.com shows it is used for all the models Patton listed. However, many of the individual parts in the kit don't fit some of the models listed because their tensioners are different. Very confusing. Ed
28 Sep 2012 18:15 - 28 Sep 2012 18:51
#551442
martin_csr wrote: I think Patton made a boo-boo....
Thanks, martin! :cheer:
I referenced Tensioner Kit 99996-1021 instead of Cam Chain Tensioner 12049-1015. :huh:
Good Fortune! :)
Last edit: 28 Sep 2012 18:51 by Patton.
  • martin_csr
28 Sep 2012 18:27
#551448
Is that Tensioner Kit a manual type? I didn't even notice that. hee.
I think I made a boo-boo too by not looking at the Kaw diagram carefully enough... hee.
  • Calico
29 Sep 2012 13:41
#551544
Ok, here is a picture of what mine looks like but mine has not been removed yet. So does anyone know if this one can be adjusted? By appearance it seems so. But my Clymer book isn't of much help here.
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
