- Thank you received: 29
Leaking oil from the shift shaft/lever.
- Del_Herring
18 Sep 2012 16:45 #549484
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic Leaking oil from the shift shaft/lever.
If that aint it, I got nothing, couldn't find anything either under their transmission or gear change parts blowups.
The following user(s) said Thank You: Sbanes81
- 4TheKZ1000
- Visitor
18 Sep 2012 16:57 - 18 Sep 2012 17:07 #549488
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Leaking oil from the shift shaft/lever.
Del is the man......92051-005 - OIL SEAL,TB 13225.5 I sourced the part for 1981 KZ 550 A1
www.gearhead.com/all/92051-005.html?utm_...#/s/KUS//92051-005/1
www.powersportsplus.com/parts/detail/kawasaki/KP-92051-005.html
Attachment sealm.png not found
Last edit: 18 Sep 2012 17:07 by 4TheKZ1000.
- Sbanes81
18 Sep 2012 17:03 #549491
by Sbanes81
Replied by Sbanes81 on topic Leaking oil from the shift shaft/lever.
You guys rock! which website is it from? I will order it now!!!! saved my bikes life!!!
- 4TheKZ1000
- Visitor
18 Sep 2012 17:08 #549493
by 4TheKZ1000
I linked some sites for you above
- Sbanes81
18 Sep 2012 17:11 #549495
by Sbanes81
Got it from cheapcycleparts.com! $15 bucks! thanks so much everyone!!! Will update when it is installed!! :woohoo:
- Sbanes81
18 Sep 2012 17:13 #549496
by Sbanes81
Ok didn't see those links for some reason? But same price with shipping same part number. thanks again
- 4TheKZ1000
- Visitor
18 Sep 2012 17:16 #549497
by 4TheKZ1000
No problem...glad to help....give it up to Del for the find
- Sbanes81
18 Sep 2012 20:27 #549542
by Sbanes81
Thanks DEL!!! Your the man! I'll try to post pics of the process and post on this forum. They sold a million of these bikes back in the day, I'm probably not the only one with this problem!?
- Del_Herring
18 Sep 2012 21:35 #549567
by Del_Herring
Glad I could help, sometimes you just have to look in the place that it clearly isn't, because they probably let some intern make their webpage who didn't know anything about motorcycles or the fact that a breather cover is unrelated to the transmission cover on there. Oh well.
Incidentally, I think my KZ is fine, but I know I have an old ZX that has exactly this problem, so you definitely aren't alone. And without ever having mentioned that bike on this forum, I've probably picked up enough general knowledge to solve that bikes problems far more than when I dug around other Kaw forums back when I was working on it.
