Leaking oil from the shift shaft/lever.
- Sbanes81
17 Sep 2012 12:43 #549230
by Sbanes81
Leaking oil from the shift shaft/lever. was created by Sbanes81
I can't seem to find the replacement o ring for a 1981 kz550 shift lever. There is oil leaking and it would be nice to stop that. Any help would be appreciated. I have look on Z1 and they don't seem to have one for this model.
- wireman
- Thank you received: 299
17 Sep 2012 13:03 #549238
by wireman
Replied by wireman on topic Leaking oil from the shift shaft/lever.
You might try calling them directly to see if they sell it seperately from full gasket set.
While youre there you might want to tell them somebody put the seals in the middle of one of the gaskets to look like a smiley face which is not the kind of thing we need here on a serious motorcycle website!
Tell them to keep that stuff in chit chat! :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
The following user(s) said Thank You: Sbanes81
- 4TheKZ1000
- Visitor
17 Sep 2012 13:06 - 17 Sep 2012 14:01 #549240
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Leaking oil from the shift shaft/lever.
on the kz 1000 there are two seals...about the size of a dime....one is pressed into the trans cover and one in the clutch cover....I dont know about the 1981 kz550 I will look around.
These are the two on my KZ1000 (redline cycle pic) see attachment
Last edit: 17 Sep 2012 14:01 by 4TheKZ1000.
- 4TheKZ1000
- Visitor
17 Sep 2012 14:59 #549267
by 4TheKZ1000
didnt see anything to help you...will keep looking
- Sbanes81
17 Sep 2012 15:08 #549268
by Sbanes81
Replied by Sbanes81 on topic Leaking oil from the shift shaft/lever.
That is what my seals look like... Just not sure of diameter of yours compared to mine? Thanks for all the help I will continue to look and I will give Z1 a call to see if they carry anything that will work!
- 4TheKZ1000
- Visitor
17 Sep 2012 15:13 #549272
by 4TheKZ1000
ya they have a metal collar with inner rubber seal...looked on Z1E web but didnt see them....
- Sbanes81
18 Sep 2012 13:26 - 18 Sep 2012 13:28 #549448
by Sbanes81
No luck finding anything for this year and model. Found some seals that look so much like what is on my bike that i'm wondering how different these seals can be if it is made for a Kawasaki and the shift levers are the same diameter...right? I found this one on Liskas.com.
Its 6 bucks so.
Its 6 bucks so.
Last edit: 18 Sep 2012 13:28 by Sbanes81.
- 4TheKZ1000
- Visitor
18 Sep 2012 15:23 - 18 Sep 2012 15:24 #549464
by 4TheKZ1000
The seal out of my 1980 A4 is .7612 of an inch (outer diameter). If you can get a measurement from yours or the liska one you can move on. You now know the diameter of the KZ 1000 does it match your 81 KZ 550 A..????
Spencer
Spencer
Last edit: 18 Sep 2012 15:24 by 4TheKZ1000.
- Del_Herring
18 Sep 2012 15:30 #549465
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic Leaking oil from the shift shaft/lever.
also check Kawasaki.com for interchangeable parts between the models.
- pete greek1
- Thank you received: 185
18 Sep 2012 15:40 #549469
by pete greek1
Replied by pete greek1 on topic Leaking oil from the shift shaft/lever.
if you know the part number, just Google the part # & you'll find many places that sell them....Pete
- 4TheKZ1000
- Visitor
18 Sep 2012 16:31 #549481
by 4TheKZ1000
There is no number...or does the part show on any diagram?
I called Z1E...no help....
looked on Kaw.com....no help....
looked on ebay....no help....
goggle....no help
WTF
goggle....no help
WTF
- Del_Herring
18 Sep 2012 16:42 #549483
by Del_Herring
I'm at work, so no pics right now, but if you go under the kawasaki parts diagram for the Breather Cover/Oil Pan, there's another piece there that looks like it might be what you're looking for. Part number 9 on there is an oil seal that looks about right. Part # 92051-005 and is still active. Definitely double check that I'm looking at the right thing before buying, I haven't worked with the 550's, but the hole looks about right for where the shift shaft comes out.
